2000 4runner - camshaft position sensor resistance?
Old Dec 11, 2012 | 03:43 PM
43jeeper's Avatar
When checking the resistance on this sensor, would a reading of 1.104 indicate a faulty sensor, or is my meter display simply showing me 1104? I adjust the fluke to show me a reading in k ohms, and it reads 1.104. The FSM says it should read between 835 - 1400 k ohms, cold. This engine is cold, havent started it for days. Meter says 1.104 - is that a bad sensor?
how often do these actually go bad and how often do they cause misfires? ( I recently replaced the TB/WP and reverified the timing marks line up, on every second rotation of the crank pully.)
Old Dec 12, 2012 | 08:40 AM
43jeeper's Avatar
bump...
Old Dec 12, 2012 | 10:25 AM
MudHippy's Avatar
The FSM says:
at cold 835 - 1400 Ω
at hot 1060 - 1645 Ω
1.104 kΩ = 1104 Ω
What codes are leading you to believe there's a misfire?
Old Dec 12, 2012 | 10:27 AM
43jeeper's Avatar
P0300
P0302
P0303
OK, thanks for clarifying the resistance values. As fancy as my fluke meter is, it doesnt seem to have a way of rolling that decimal out to the thousandth position.
mskalmus
May 28, 2017 07:51 AM
smiley52
Jul 11, 2015 05:16 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
