Jump start with cables crossed now no power at all
Old 01-16-2013, 05:09 PM
Kludo's Avatar
Wife got a jump start on 96 4 cylinder 4Runner with cables crossed. Got a new battery and installed it. There is no power at all to the vehicle. Dome lights won't even come on. I assume it blew fuse or worse, but don't see anything that looks burned out or funny. Any ideas?
Old 01-16-2013, 05:13 PM
Mr_Random's Avatar
If I remember there should be a fusible link for your truck? Google it and you should be good!
Old 01-16-2013, 05:24 PM
Duncan4x4's Avatar
mayabe checkout you ECU or your powr relay
Old 01-16-2013, 05:55 PM
bbrideau's Avatar
80 amp fuse in engine bay fuse block. need to slide it out unbolt with i believe 8mm or 10mm bolts on either side. i did the same thing.
Old 01-16-2013, 06:27 PM
Kludo's Avatar
Thanks for the ideas, is there a way to tell if the fusible link is burned out without taking the entire fuse box out? Strange but I don't have an 80 amp fuse, just a 100 amp one that's labled starter.
Old 01-16-2013, 06:37 PM
98SR54RUNNER's Avatar
Here's a writeup on how to swap your fusable link:
http://www.toyota-4runner.org/3rd-ge...ks-w-pics.html
Also, make sure your ground wires are all good. This should set you straight, no big deal.
Regency
20
01-03-2020 07:43 PM
voiddweller
19
05-02-2016 09:10 PM
layifioren
10
07-06-2015 02:26 PM
OffroadRalph
07-02-2015 07:28 PM
rbravo1
06-29-2015 01:34 PM
Quick Reply: Jump start with cables crossed now no power at all
