- rear axle seals leaking
- Which one is the transmission return line?
- On my 3rd rear axle seal. What should I do?
- 96 4runner 2wd electric probs...
- "Tacoma" Whip Antenna Mod
- Cut-Out Flares Question
- Sonoran Steel LLC.
- 1998 4Runner Corner Lightbulb replace =PITA
- Need new suspension, have sonoran steel
- Grey wire mod w/ stock option
- Oops I galvanize sprayed my sliders.. can't prime or paint them now?? :O
- tundra disc brakes swap
- 99 springs
- I'm getting a TRD-style sticker made... What should it say underneath?? :grin:
- Do timing belts on these trucks really cost this much near harrisburg pa???
- 96 4runner E-locker mod: I want to be able to use it whenever.. HELP!
- Beware the trailer light controller
- Loss of brakes on highway
- New lift pics
- Steering wheel play in 2001 4runner
- Grey Wire Mod???
- Feedback on the Tundra upgrade for my 99 4runner
- Check Engine 4cyl. 2.7L
- 2500RPM, moderate acceleration, transmission clicking (like relays)
- probelms with 4x4 on 2002 4runners???
- Question about 2002 tacoma XTRA cab!! HELP
- mini bulbs
- brake rotors
- Fuel Pump Sabotage???
- What's a reasonable price for this particular WELD/FABjob? Cud I be gettin 'jipped'?
- Replacing rear Licence plate shroud..97 PITA?
- OBX Pacesetter headers on a 5VZ-FE 3.4L motor...
- New HU installed and Front Tint
- Stress of 4runner?
- What is the size of the bolt that holds the radio motor on a 96 4runner
- I'm back!
- Shocks/struts
- 1996 or 2002 front seat question?
- Transmission or brakes feel like their dragging during deceleration
- mounting offroad lights?
- What to do on a boring thursday night...
- Key removal problem.
- Xenon Sport Flares (for 4Runner w/o RUNNING BOARDS)Install w/Powdercoated Bumper/PICS
- No Electrical power
- 2002 4runner limited new tires!
- D-E-D, dead out of the blue
- Quick lift question
- 880/906 question
- RS3000 or not?
- R150f Tranny questions
- Help speedometer and rpms are dead
- milky trans fluid, bad radiator?
- Bandit Runner's Cargo Box
- Alignment
- Steering Rack Bushing Replacement
- ac compressor issues
- *** Seat upholstery? Where to find? ***
- Seats are a pain in the you know what.
- MIl/Check Engine Light smog fail
- SCUBA's Taco is LIFTED !!!
- Pain in my MAF
- ARB diff cover?
- New Wheels Installed - Eagle Alloy Series 137
- 4Runner Officialy Totaled, looking for replacement
- Anyone running 1.5" Daystar lift?
- shocks
- need help with replacing shift lever seat
- are all 95.5 to 2004 tacoma frames the same?
- Wheel fitment with Tundra Brakes
- Do I need to do a HG job or am I just being paranoid?
- More Power Steering issues
- Help. Cigarrete lighter and outlets dont work
- Question on recent steering rack bushing change?
- 2000 4runner RPM's wont go down
- 1999 Toyota 4runner Highlander Edition
- Quick towing question
- need seats for 96 4runner
- 99 4Runner Auto -- Shifter Knob Removal????
- towing with 03 tacoma double cab
- Will tundra brakes work with 15" stock al. wheels?
- where to get a steering rack?
- 97 4runner bucking on hills
- ARB front rubber bumper pieces
- Some bling and some Lift Help
- swapping 96 to 99 axle differences
- reboot or replace
- '04 Tacoma - auto to 5spd??
- Front/Rear Coil Replacement - Suggestions
- Newer Ride
- long travel suspension 96 tacoma
- Parking Light, Turn Signal Mod, Blinker No Drilling! Video Link
- Newish 4Runner Owner
- Check engine light help
- Bit the bullet and put a DP on gears install
- 3rd Gen rear tire carrier
- 3 questions
- Can the Radio unit be Swapped between MY?
- Ac Recharge
- 3rd Gen 4runner and 200k miles?
- Another Cargo Drawer Build...
- Help! Replacing front bearing on 4Runner
- Name that part... Heater control valve?
- need help dx my motor
- Problem with bushings
- 3D Model of Tacoma
- Got me a new truck!
- Yotas with Viair On Board Air...
- 02 4runner, Is my tranny shifting right?
- Rain, P0446, and no air/AC at any speed
- body lift???
- Help: Truck won't start---not battery/alternator---Electric?
- Has any one re-built their 5VZFE 3.4 V6 engine ??
- Customized 4xInnovation Slider Steps - Pics
- Master Control Switch Doesn't Work for Pass. Window BUT Pass Window Switch Works
- Seat Belt Exchange Question
- Engine hesitation-Need Advice
- 1999 4runner front receiver
- People that have looked at their spare tire lately...
- 2000 4runner speaker replace
- Handle mod
- I cant believe some people...
- 4th Gen 4runner...TRD Exhaust or stock??
- key/lights warning chime stopped working
- pcv valve flow direction question
- NEED HELP A.S.A.P......Rear Brake Shoe Issue
- disrupting trac control in 2wd runner**
- HELP XRC8 smittybilt guarantee q???
- upper control arms
- 2wd with e-locker
- Anyone running the '99 lift setup (system 3.0)?
- 1st Gen TRD "Gray" Supercharger Install Guide
- Complicated Problem Codes P0120, P0171, P0505
- Cat-Back Systems
- size of bolts for back seats?
- which are the best auto parts retailer thesedays?
- Airbag Sensor
- Lights for Radio Station and also Climate control out
- Interior light replacement
- Hood latch adjustment on 99 runner?
- Need Help! Tacoma Front End Question
- key getting stuck..intermittent problem
- A/C Problem
- Power Steering problems (it's been a pain)
- 3rd or 4th Gen 4runner?
- 5vz timing issues
- Dumb oil change question 99 runner 6cyl.
- cat converter stolen
- elocker little by little?
- NEED HELP! Car shaking badly.
- Brembo blanks and Akebone ProACT ceramics...
- Spare steel rim and Tundra brake
- Another Vibration Thread...
- Exhaust leak...ideas?
- 3.4 Gaskets
- Tacoma 01-04 vs 05 and newer?
- 99 runner diff fluid
- Updates pics of my Tacoma: Tires, lift, etc and some questions!
- How should I run the wires from my roof lights down to my engine?
- How to install K&N intake with 3" bodylift..??
- Performed spacer lift, both inner CV joints threw up!!!!! What to do...
- Brake experts: Biggest brakes that will fit on a 96' 4runner limited with 17" rims?
- 99 tacoma 4x4 cylinder 1 misfire
- Another FJ wheel question
- Landcruiser 80 Rims Question
- Hard starting. HELP
- 99 runner swaybar bushings.....a question
- how to replace glove box light bulb
- bumper opitions....
- Brush Gaurd
- cluster issues
- Time to replace oxygen sensor?
- A/C and gauges not working, fuse blowing
- Cant wait to start modding my 4Runner!
- Could it be a U-Joint??
- 2001 Taco; 3.5" front suspension lift, what to do about the rear, (NO AAL's)!?
- electrical pop
- X-runner wheels on a 2001 Tacoma??
- Polyurethane tie rod Bushings??
- Direction of coolant flow?
- p1135 o2 or a/f s?
- rear axle seal repair cost?
- Tundra Brakes for 3rd gen 4Runners on Off-Road.com.
- How about this for a TRD decal?
- 2001 4runner fog lights
- Anyone have pics of 3rd gen 4runners with 4" taco front susp?
- Releasing brakes, thump noise and jerk action?
- rear double shocks
- X-Cab Tacoma rear side window latches broken - common issue?
- 4runner 35" no cut no tubbing
- New heads, strange sound
- 02 taco auto to manual swap? 4x4
- two brand new batteries won't hold charge
- DIY fuel pump replacement
- Can i tow this 200 miles? pic inside
- Towing Suspension Recomendations
- Thinking of buying 04 SR5
- Land Cruiser Shocks on 4Runner
- Tundra Springs with Blue & Orange Paint Codes?
- Courtesy Lights
- 02 4runner multi-mode 4x4 towing?
- Ball joints/Tie Rod price
- *Locking Ammo can storage*
- One-piece drive shaft?
- Grinding noise when starting......
- Locking Lug Key Missing-- Help
- ordered OME suspension: any install tips?
- Shudder when accelerating on the highway
- 4Runner may be totaled
- wanting to replace rear license plate housing...
- Tacoma Grille Conversion to the 4runner?
- Replacement Shocks for Emu Kit
- Power window help
- Just installed a SS system #1.2 lift and 32" tires on my rig...Dial-up beware...
- 2000 4runner hesitation when i accelerate
- Need new rear bumper for '02 4Runner
- 4Runner Rear Window Issues-HELP!
- Thinking out loud sell '00 Limited for a '99 Limited
- p0115 2000 3.4 4runner...
- Reaplcing muffler and keeping old pipe...quick question
- Quick question about skids
- Water Pump Replacement Question - The new pump has a gasket, should I use sealant?
- Vibration sound
- Too many stereo cables?
- help on 02 4runner
- Cost to replace headgasket?
- 1996 4runner SR5 3.4 5vze V6 "Broken RPMS..."
- Help with stereo deck and speakers
- My new Tacoma
- Pics of setups with ome's and LC on 33's or 35's???
- Carrier Bearing question/insight
- Replace vacuum hoses?
- P0305 & P0171 Misfire
- 2001 Tacoma X-Cab 4WD 3.4 Possible purchase...
- What gearing for 35's???
- Aisin manual hub conversion
- Bushwacker fender flares
- trans jumping
- Wrecked 2nd gen/possible 3rd gen purchase
- front splash guards - part #
- Speedy's Site Overhauled
- Front end clanking 2000 runner
- engine light code P0120
- muffler dilemma
- Annoying Squealing noise 2500-infinite RPM's
- Does my 5spd 3.4 '00 taco NOT have a r150f?
- another tire question
- 4runner or Tacoma, help me decide...
- Windshield wiper problems
- Hurting -need help with rear springs sizing
