Some bling and some Lift Help
Old May 22, 2009 | 08:52 AM
scuba's Avatar
Cool Some bling and some Lift Help
Hey guys, so Im just preparing to do the lift on my taco, I have mostly everything, Still waiting on the 5150's from bilstien
I got the 3" allpro kit, which doesnt state it comes with ubolt flip kit but it does, so it also comes with lower shock mounts. As well as the extended brake line..
On to a couple questions, I dont get paid till next week, and I still need some longer bumpstops and some extended brake lines for the front.. (I am going to need ext. brake lines for 881's, Yes ?)
Does ORW sell bumpstops in store? Cause I can pick them up next week rather then ordering them and then waiting another week..
I've been reading and reading other threads to get any useful knowledge on this so Im pretty sure I have my ducks in a line, just making sure..
Thanks guys !!
Old May 22, 2009 | 09:59 AM
jdmaccord6's Avatar
i don't think you would need longer brake lines if you just want to put the lift on. If you're going to put the lift on and wheel it, maybe...when i put the 882's on my 4runner, i didn't. and i've have still yet to get longer front or rear lines.
Old May 22, 2009 | 10:05 AM
scuba's Avatar
Well I wheel, sorta hard..
Old May 22, 2009 | 11:38 AM
scuba's Avatar
So it looks like the bumpstops will be reused, I can easily put them on some plate and some square tubing I have around..
And I think I might be able to get away with out the brake lines, I took a closer look and they have ALOT of slack..
IDK ?
Old May 22, 2009 | 02:56 PM
BajaRunner's Avatar
You don't need to extend the brake lines in the front. Obviously in the rear you do.
Donno what the Tacoma bumpstops are like, but, I really like my Daystar bumpstops, I'm sure they'd work for you.
Old May 22, 2009 | 03:10 PM
algranger's Avatar
I think Performance Accesories makes some universal type bump stops... you can fab to adapt them to your truck right where your springs flatten out
Old May 22, 2009 | 05:55 PM
eddieleephd's Avatar
I would suggest Extended brake lines for the rear as well.
I also suggest taking the springs and shocks to a shop for the assembly.
pretty easy job as long as you have the proper tools and plenty of blocks.
I used a farm jack to put the bumper on blocks pulling the wheels a few inches more off the ground than needed, then used a floor jack to raise and lower the axle. I also did this one side at a time! I felt much safer this way.
Old May 22, 2009 | 11:08 PM
scuba's Avatar
The allpro kit comes with a brake line for the rear, So not worried about that..
Im pretty sure im good to go for the most part, I dont think its going to be terribly difficult so yea..
Im doing this next weekend, so ill have pics once its done..
Old May 23, 2009 | 03:43 AM
4Runner202020's Avatar
i have 883's and toytec's topplate spacer without extended front break lines nor extended bump stops.... i think you will be ok.
bobby
Old May 23, 2009 | 06:23 AM
SnowRunner98's Avatar
[/QUOTE]
Pics or it didnt happen! L Cool. just had to say that.. can't wait
you going to 33's on those 15's?
Old May 23, 2009 | 07:20 AM
scuba's Avatar
Hahah
I cant wait either
As for 33's im thinking 255/85's
Which come out to ~~33.4/10. They only make those on 16's so when im ready ill be on the lookout for some 4runner 16's, Cause I like this style..
Oh, 4Runner20 Thank you, I was hoping to get some real world advice..
Old May 25, 2009 | 10:01 AM
scuba's Avatar
So I chose to start tearing into the thing today..
Im trying to get this part off, So I can swap brake lines, the fsm says this little thing is the clip, But it wont budge..
Suggestions...?
Old May 25, 2009 | 10:30 AM
BajaRunner's Avatar
Take a flat head screwdriver and whack it upwards with a hammer. Try pushing the rubber side towards to relieve the tension.
Yes, that is the clip. I'd just keep working on it with some pliers too. It will come off going upwards .. obviously.
Old May 25, 2009 | 10:49 AM
TOYOTA 1's Avatar
yea i use needle noses for those clips. grab the small flat edge long ways and rock it up and down, it will come right out. as far as front brake lines i have a 3" spacer lift on my 2000 and theres still plenty of slack in them.
oh and 255/85/16 = 33x10.04x16
Old May 25, 2009 | 05:15 PM
scuba's Avatar
Yea I answered my own question a few mins after I asked that..
Pull Harder..
So the front struts are being asses, So im taking it all to a shop in the morning and have them assemble them for me, Cause I dont feel up to it..
But I got the rear done, Teaser pic :
Old May 25, 2009 | 05:20 PM
toyospearo's Avatar
Looks good so far. Nice height!
Old May 25, 2009 | 05:45 PM
scuba's Avatar
Its alot higher then I expected, I still havent taken measurements for the rear after, But
I made sure to get measurements all around before everything..Cant wait to get it all done though..
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
