rear double shocks
Old May 8, 2009 | 12:11 PM
turbo3's Avatar
rear double shocks
Hi to All members of this forum
I write from Kazakhstan may be same peaple hear about my country.
I didn't find any information about double shocks in rear, so I have question for you.
I plan install additional shock in rear but I can't find the place fot it.
So anybody made it? Who find the place and how insatalled, which shocks used?
Sorry for my not good English.
Old May 8, 2009 | 12:22 PM
96spicytaco4X4's Avatar
u know my buddy borat?
Old May 8, 2009 | 12:24 PM
algranger's Avatar
Just curious why do you want to install double shocks?
Old May 8, 2009 | 12:27 PM
turbo3's Avatar
I know. Did you see borat II? )))
Old May 8, 2009 | 12:33 PM
turbo3's Avatar
Reasons:
1. My shocks from TLC 80/100 with blue label(very firm) not enought.
2. I don't want bay expensive shocks. TLC 80/100 OEM shocks is cheap 30$.
Old May 8, 2009 | 12:35 PM
904_runner's Avatar
If its cheap you could try it.
I think what you are looking for is stiffer springs most likely. Try the double shocks, if they suite your needs then go for that, if not it might be time to look into new springs
Old May 8, 2009 | 12:53 PM
turbo3's Avatar
Yes I have stiff springs +300kg I need it because I load SUV very heavy.
Old May 8, 2009 | 01:22 PM
swapped89's Avatar
Sounds like dual shocks will take some metal fabrication. You need to find an area on the axle and an area on the frame of the SUV to weld on some aftermarket shock mounts. like the ones from, trail-gear.com
http://trail-gear.com/shocks.html
It will take some simple math and measuring.
Maybe someone else will have a solid idea but thats all i got.
Old May 8, 2009 | 01:31 PM
904_runner's Avatar
oh okay.
You could try looking into an AIR RIDE suspension. I believe there are airbags that can go inside coils if that is what you have, and they also have airbags for leaf springs. Im not too familiar with them so you could look them up. I believe they help tremendously when carrying a lot of weight.
Old May 8, 2009 | 06:51 PM
SnowRunner98's Avatar
only thing is shipping is going to be pricey! air bags, or coil spring replacements would be my idea. could he get by with some air shocks (bolt in application) ?
Old May 8, 2009 | 07:38 PM
algranger's Avatar
oh okay.
From what i gather, it sounds like he is sprung for the heavy load but the ride is bouncy.
Turbo3- If you know someone or somewhere that you can have some fabricating done, it would be easy to weld the mounts onto the axle and frame
Old May 9, 2009 | 09:11 AM
turbo3's Avatar
The problem is that to find place in the frame and axle.
So I'm looking for people how made it(double shocks).
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 14, 2015 10:23 AM
akaphilly
Jul 9, 2015 02:34 PM
