2000 4runner hesitation when i accelerate
Old May 4, 2009 | 02:32 PM
garnbill's Avatar
i have a 2000 4 runner 2wd v6 and when i go to accelerate 0 mph to 1 mph theres a hesitation where nothing happens and the motor dies a lil bit then it takes off and runs great from there on so at red lights and anytime i stop this happens and now it just started to run rough right when i start it then it clears up and runs allright anyone know what this might be i was told either an 02 sensor or a fuel pump? the check engine light is on and autozone says something to do with bank 2 running rich and running lean picture that!
Old May 4, 2009 | 03:04 PM
stir_fry_boy's Avatar
please post code #'s.....
Old May 5, 2009 | 04:31 AM
garnbill's Avatar
I will post codes later today
Old May 5, 2009 | 04:48 AM
BigBallsMcFalls's Avatar
consult crystal ball - dirty maf
Old May 5, 2009 | 05:46 AM
garnbill's Avatar
ok i took off my maf and i was looking at the wrong prongs on it the ones on the inside are filthy i think one might even have hair wrapped around it so im going to go get some contact cleaner and soak it down ill let you know in about 3 hours if it worked thanks
Old May 5, 2009 | 06:54 AM
oh yeah reset your ecu. pop the battery cable, go have a sandwich, come back in 10, drive.
Old May 5, 2009 | 06:56 AM
use spray maf cleaner, like crc. something guaranteed to leave no residue of it's own. it might take half the can to clean a really dirty maf element. let it soak, blast it but don't physically touch the wires with anything. the slightest bend in the wire will change the signal it produces. you don't want that. spray won't hurt it though. (a q-tip would)
Old May 5, 2009 | 07:15 AM
garnbill's Avatar
Dude you're the man its all fixed cleaned and the check engine light is off and it runs great again thanks alot you saved me some money it only cost me a $6 can of maf cleaner!!!
Old May 5, 2009 | 08:40 AM
garnbill's Avatar
since my maf was filthy and my 4runner rand like crap would that of made me get terrible gas mileage too or have nothing to do with that?
Old May 5, 2009 | 08:49 AM
probably, no way to tell until you drive it after and see what you get. After cleaning mine and doing some routine maintenance, I increased mine from 17 MPG to 21 MPG. That included cleaning out both filaments in the MAF.
Old May 5, 2009 | 08:58 AM
Fink's Avatar
Yes, it would definitely effect your mileage.
Cleaning your MAF is one of the easiest and most beneficial things you can do for your Yota.
Glad you got your codes and problem fixed.
Fink
Old May 5, 2009 | 09:58 AM
yup it can nuke gas mileage
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
