Annoying Squealing noise 2500-infinite RPM's
Old Apr 29, 2009 | 04:33 PM
xcmountain80's Avatar
Well I thought it was a ac compressor belt being loose but noooo. I replaced the pensioner pulley as the old one had a light click when you shook it. Well needless to say it is still whining like a $2 whooooa bicycle. I thought maybe vacuum hose but can't find a thing.
Aaron
Old Apr 29, 2009 | 09:14 PM
SoCalPaul's Avatar
Did you replace the belts? The alternator bearings could also be bad.
Old Apr 30, 2009 | 04:16 AM
Belts had been replaced, dunno how to check the ALt. bearing short of just grab and wiggle it. Is it just the pulley bearings.... or the entire alternator? My dad keeps telling me it sounds like a whistle which would indicate a vacuum leak, I checked my vac. lines and noticed some were aged and other looked fine.
Aaron
Old Apr 30, 2009 | 05:47 AM
BajaRunner's Avatar
Does the whistle change with higher RPM?
Old Apr 30, 2009 | 09:54 AM
Why yes, yes it does. Starts lightly at about 2500 rpm's and then progressively gets louder.
Aaron
Old Apr 30, 2009 | 12:48 PM
bjslade0269's Avatar
I just checked mine last night. I took the alt. belt off and the noise stopped. So looks like I get to buy an alt.
Old May 1, 2009 | 05:23 AM
I don't know if mine will start w/o the alt in place, I Know some older ones will but not so sure. And if I have to replace it I'm going mean green.
Aaron
Old May 1, 2009 | 05:51 AM
Bighead's Avatar
Aaron
Are you still selling it?
Old May 1, 2009 | 06:50 AM
BajaRunner's Avatar
Well, it sounds like its definitely a rotating part. I know you already knew that though.
If it were me, Id spray some silicone spray on the pulleys, to see if it helps at all...obviously try not got any on the belts themselves, or the contacting surface.
I hate little noises
Old May 1, 2009 | 02:02 PM
Nope I decided to keep it because I love it sooo much! I think either a SC or Irbis rear are in the works one or the other.
Aaron
Old May 2, 2009 | 05:31 AM
Replaced my alt. with a $25 used one and my noise is gone! Now it's time to have my old one rebuilt. I hope you track down your noise soon.
Old May 4, 2009 | 04:15 AM
Which vehicle was this on?
Aaron
Old May 4, 2009 | 04:54 AM
the 99 tacoma 2.7
Old May 4, 2009 | 05:44 AM
Ok so it's at least somewhat applicable. Man I Hate to buy an ALT and have it not fix the problem. But I Had noticed my dual battery manger thats acting odd and a bad ALT might have something to do with it.
Aaron
Old May 4, 2009 | 09:28 AM
Lets see it's $128 for a ALT + a core, I called around to find out about seeing if I can get the old one rebuilt for a price and perhaps about 150 amps. Mean Green makes em but there $400. Youzer.
Aaron
Old May 4, 2009 | 09:36 AM
NicCantDecide's Avatar
I was having the same noise problems and I've had a 150amp Alternator that I've been neglecting to install. Installed it a couple days ago and my noise problems went away.
I also did the big 3 wire upgrade while I was at it, upped everything to 4awg.
I paid somewhere around $200 for my 150amp alt but I don't remember where from. Just look around online.
Old May 4, 2009 | 09:37 AM
I hope my used one lasts a couple of months so I can get my old one rebuilt. I don't run anything more than stock electrical components on this truck so hopefully a rebuild will be cheap for my old one compared to buying a new one.
Old May 4, 2009 | 10:00 AM
Oh you tease! You can't remember where? WTF kidding kidding I'll search.
Aaron
Old May 4, 2009 | 06:05 PM
Well it isn't the alternator, as I swapped in a new one and same noise. I fear it may be a tranny bearing or perhaps a water pump. I forget what the WP sounds like when its going.
Aaron
Old May 11, 2009 | 07:32 PM
sdsurfer's Avatar
dude I had the same noise. louder when off of throttle and lounder as I sped up. Wheel bearing and right rear axel seal replacement fixed it all!
