cluster issues
Old May 10, 2009 | 07:10 PM
rlee_tacoma97's Avatar
cluster issues
Hey gang, I got a cluster issue. The first symptoms I realized was the speedo needle jumping erractically and making a scratchy noise. Then the speedo and odo went dead, the tach is running fine though. MIL came on, pulled code P0500 VSS Sensor. Give me your opinion, is it the cluster of the VSS??
Old Dec 24, 2009 | 09:56 AM
UpInSm0kE's Avatar
Did you ever figure this out have the same problem all of the sudden the speedometer stopped working this morning and the CE ligh came on and is throwing code P0500. Did you check your Speedo cable behind the cluster?
Old Dec 24, 2009 | 10:21 AM
Ironmike4x4's Avatar
Check your fuse first, mine did this and the fuse had blown and the same DTC. I put a new one in and it blew again. I had to trace the wire for the IPC and found it was shorted to ground on the fuse panel side under the dash. Repaired the wire an no problems as of yet.
Old Dec 24, 2009 | 12:36 PM
UpInSm0kE's Avatar
Mike isnt the 98 a electronic speedo? Mine is a mechanical speedo behind the cluster. Is there a fuse for this as well?
Old Dec 24, 2009 | 01:03 PM
I was wondering that myself about yours when I posted my answer. Yes mine is an electronic speedometer but not digital. I'm not sure if the mechanical would have one other than background lights.
Old Dec 24, 2009 | 01:10 PM
UpInSm0kE's Avatar
Mine is a mechanical speedometer cable with a analog odometer. I will have to pull the cluster out to see if it fell off behind it. Those cables are really hard to get back on because there is absolutely 0 slack behind the cluster.
Old Dec 28, 2009 | 08:29 AM
UpInSm0kE's Avatar
Well I pulled apart my cluster yesterday and the plastic pin that goes into the back of the cluster is busted. Does anyone know how hard it is to replace the entire cable? It does not look easy at all just looking at the route it takes and a rough idea of how much it costs at the dealership?
nvdesertrunner
May 11, 2020 08:18 PM
mussy01
Dec 13, 2016 08:20 PM
gary4runner
Sep 24, 2015 12:53 AM
Esibnitsud
Jul 30, 2015 08:21 PM
