p1135 o2 or a/f s?
Old May 9, 2009 | 05:10 PM
roadtripgeorge's Avatar
p1135 o2 or a/f s?
So i got a p1135 code and a p0420 as per autozone.
i have a 2000 4runner. from what i've read, the p1135 is the air fuel sensor. when looking up the part to order at underdog racing dev, (http://www.urdusa.com/index.php?products_id=1260518950), i saw that I might just need an 02 sensor instead of the really expensive a/f sensor. part number 234-4162.
i took a look under my truck and saw 1 resonator and 1 cat, from what i can tell, leading me to think that I have a non-cali model. I live in NJ but i didn't buy the truck new so who knows.
i thought maybe the resonator was a cat with the heat shield knocked off, but I don't think it is.
can that be right? im not sure where, but i think i read that with some newer models 02+ definately have an a/f sensor, and that the older ones were just an 02 sensor, but wanted to check some other opinions first.
in no way would i want to spend the $150+ on the a/f sensor if I can get away with an ~$80 o2 sensor.
any help would be great!
Old May 10, 2009 | 09:06 AM
GSGALLANT's Avatar
You probably already know this, but the description for P1135 is: "A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) (California Spec.)"
Old May 10, 2009 | 12:42 PM
am i right in thinking that to determine if I have a cali spec truck, i would look at the exhaust.
1 catalytic converter = non cali
2 catalytic converters = cali
so if I have a 2000 non cali spec 4runner, with the p1135 code, would that then suggest I use an o2 sensor and not an a/f sensor for bank 1 sensor 1?
thanks!
Old May 10, 2009 | 02:51 PM
GSGALLANT's Avatar
That's what I always thought for the cali vs non-cali question. Not sure about your other question. Go to the dealer and give them your VIN. They should be able to tell you what you need.
Old May 10, 2009 | 06:29 PM
i think you're right. visiting the dealer would be the safest way to go. thanks gallant! i will update with what i learn at the dealer tomorrow.
TheNimrod
24
Sep 27, 2012 07:58 AM
sigley0527
Aug 6, 2011 03:39 PM
Primo
Sep 11, 2007 01:24 AM
Bob_98SR5
Jan 14, 2006 09:41 PM
