- Anti-Rust
- Air Conditioning Fan Thought
- Paxton SN-89 for 3VZ-E
- LCA drop bracket/lift questions.
- Tie Rod Replacement
- R150F question
- blinkers not blinking (3rd gen)
- Who here has a desert dune 4Runner and has used their touch-up paint?
- High mileage oil?
- SEAFOAM and Superchargers
- backed into a pole, and another question...
- 2005 Tacoma
- soft brake pedal
- Need help identifying my new '97 4Runner
- Alpine Video BLACK BOX Install!
- SEA FOAM 3.0 where to put it?
- replacing all bushings
- Timing Cover worth it?
- Which one is prefered? Upper a-arm??
- WARNING: Please read if you have headers and a 5-speed (5VZ, 3VZ?)
- Spark plug binding
- 2 new problems today
- Superwinch hubs.
- Optima Red Top
- Air Conditioning Moldy Smell
- Brake light on 1994 Runner ????
- Name this sound.
- Good prices on new '99+ headlamps
- Sign of a Bad O2 Sensor?
- 1987 P/U, Brake Rotor Removal
- Beginner Mods / Enhancements...
- Rancho 5009 shocks
- overdrive?
- 3rd gen supercharged, spark plugs
- Repair Questions
- Oil Plug help...
- 15x10 wheels, 33x12.50 tires - - Lift?
- Q for 22R-TE digital dash owners
- need some help, broke off a skid plate bolt
- 2001 Tacoma & 15" Wheels???
- Dash Lights
- MAF from a turbo supra ? -
- So What Do You Think???
- Any write ups for changing the drive shaft universial joints?
- Who's 4runner is on the Paragon site?
- Idle surges
- Damn gas mileage
- updates on my 3.notsoslow project
- 2003-04 4Runner Windshield deformation
- Houston Area Folks!!!!!
- ATS Users - ball joint versus uniball
- need some feedback
- body lift for 84-85 runner
- Newbe here! I have Questions
- JD Power 2004 top 10
- PB Blaster - I think I love you. 2nd gen fuel filter write up.
- Front end suspension making noises
- Front diff removal help needed
- quick 2wd hub help!!!!
- Time to convert my dash lights to Blue
- Armor All = No bueno?
- Test drove a Runner today
- 31x10.50. vs 235/75
- Those Considering OME Items
- HELP: How do I access the CV nut on my 3rd gen?
- is anyone running a chip in the 3.slow?
- Gauge Swap wiring help
- Fuel filter question, need answer asap
- my 4runner is dead!!! Help!
- AFTERMARKET EXHAUST....NewB Q
- I just got quite the upgraded vehicle!!!
- bumping noise at low speeds.....
- 4th Gen Airbox Mod
- New clutch questions
- major tuneup... what should be done?
- 2 Questions....
- 4Runner factory locker code and other 3rd gen ?'s
- 3rd gen 5VZ-FE engine air filter
- Left Bank Lean code
- Anyone deal with Can-back lately?
- Electric fan question.....
- Want to Buy 96 4runner lift
- get the truck, or keep the 4Runner?
- Got an old Smittybilt guard for 1st gen 4runner?
- steel brake lines worth it?
- Anyone else have their stock cd player die?
- Good deal?
- help
- Hard braking = damn scary!!!
- Camshaft in 22R/RE
- Who has a power antenna motor to sell/give me?
- pro comps or ranchos
- 5w-30 versus 10w-30 oil
- will the 3.0 2wd t-100 1993 bolt to a g-54
- Where's the heat sending unit?
- supercharge 3.0? not standard noob question
- On vacation need help from the toyota gurus!!
- Fixes for a pitted windshield?
- need a photoshop and an opinions on wheel color
- hard to start, battery? starter?
- Got Tinted
- 3vze E-Bay Alert..
- k&n fipk, loud mas sound at idle on 2nd gen
- Swapping front diffs (housing and all): Tips and Tricks needed
- Value of TRD Supercharger when buying used
- supercharger noise?????
- 3VZ intake
- Roof rack.....need some input
- Can I Mix Fender Flares And Running Boards?
- Sahara Bar Woes
- Power door locks
- New Member! Pic of my rig!
- Anyone have experience with an Overcamp?
- Engine cleaning day
- No power... fuel pump going?
- OME 882's and 02 double cab?
- Dual Remote Filter Location? - New to Yota
- Clarification on Factory Window Tint????
- What is that smell?? Help!
- 3rd gen Disco????
- 1st gen speedo cable
- a couple questions
- Anyone tried 32X11.5's with BJ Spacers?
- 22RE Fuel Grade Recommendation
- Where to Buy Peel-N-Seal
- 2nd gen clear tail and running lights?
- 95 4runner manual
- Auto tranny: Increased my mpg (a tad)...
- *HELP* Leaking oil, need to know what is leaking...(pics)
- 'oo tacoma shakes
- Power Antenna - Stuck Up and No Motor Sound and other Antenna Questions
- Top out spacer question
- Broke my end-links! Need your help, please!
- Confirmation Please - Conflicting Info
- Panel door lights and steering column lights on
- Where to mount my 1000 watt inverter?
- Car Wash Crazy
- Good welder in San Diego
- My new mod.
- 3.5" lift coil for tacoma
- Toyota Rusting Bad!!
- 2XL, after locking hubs! ! ? ? ! ? ?
- 4th gen body lift
- Oh how my Runner breaks...
- Broke my ARB locker
- Custom Grill Update...
- 01 taco auto to 02 5 speed??
- What are my truck's specs?
- This Used To Be A 4Runner!
- 2 questions bout my 99 runner...limitedslip/stepsidebars
- what can i do?
- Certified Used 4-runner
- Places for off-road adventure in Arkansas??
- Lifting an 88
- Bed Liner Roof Rack
- ECT Switch: Maybe use for something else?
- Leveling out my 4Runner
- Line-X bedliner
- 3rd gen. Broken sway bar bushings
- Towing hitch wiring harness extension...?
- 31x10.50R15 tires too much on a 2.7L?
- More manual hub problems...
- Downey's site sucks...
- exhaust size..need help
- Running Rich
- 4th Gen exhaust drone
- What Seattle area dealer parts open on Sunday?
- clutch button problem
- 95 4runner overdrive
- 1st Gen rear seatbelts and fuel door release?
- Selling '03 Sport wheels
- Opinions on Truxus Mt
- Aisin painting
- ISO: A used spacer lift
- 2g 4runner Rear Window Stuck
- Mechanical/Emissions out of state?
- I dont know what I did... but it worked
- oil loss (do you agree?)
- Fog lights wiring
- Mr. Clean Car Wash System
- SUV rollover test proves...
- Slick Deal 800W Inverter
- Steering wheel can't be set back to center
- Quick Tire Size Question (already searched!)
- engines
- Selling my Rig
- Crandon International Off-Road Raceway
- DeMello Rear Tube Bumper
- exhaust shop pricing
- Need help finding a Laptop Car Mount
- power steering not working after leak fixed
- where can i pick up some Truck seats?
- quick ISR question...
- Worn Panhard Bolt
- Landcruiser rims for 3rd gen 4runner
- Poll: what should I get, auto or manual?
- Vibration? ? ? ? ? ? ? ? ? ? ? ? ? ? ?
- Oil Filter question.??
- reese wiring harness help...
- '04 V8 4Runner stumbles/misses under medium acceleration
- Finally got pics of my '84!!
- ARB Compressor Seized?
- Where can i get a 1/8" SPacer
- Head Unit Removal
- gold emblems
- let's talk about flooring for a safari basket
- Oil: Synthetic vs. regular
- air filter/intake
- Does Anyone Know???
- fabtech lift...do you like it?
- Rockcrawler choice.. FJ40 or '85 p/u 4runner?
- What Do You Guys Think About This?????
- wheel refinishing?
- 2005 Tacoma Opinion - Read
- 4th Gen rear window
- A/C problems
- Shackle Hangars
- clutch problems
- coolant question
- Oval vs. Round Body Muffler..Confusion
- 3.0 runnin rough...
- viprs3200 alarm
- Oil plug gasket question
- CA smog help
- is this fair?
- Help with installing hellwig sway bars!
- Where did you buy....
- Another Tire Thread (2nd Gen 4Runners)
- Master cylinder symptom?
- Suspension Questions
- Sport Badges
- Need fog light advice. Compact but powerful?
- guess I am keeping my runner
- 22re oil pump collar
- 3rd gen Downey/ Bilstein
- toolbox installation
- Engine flooding with gas? after idling for a while.
- Down Pipe From the Header
- Hey Norcal! Kids need your help!
- O2 sensor wiring help
- 1st gen power mirror kits?
- Unimog vs. My Work Truck w/ Pics
- Hummin Up front - Quick Question???
- replace master or both cylinders for clutch?
- What Does SR5 Stand For?
- passenger window off track?
- Old Runner , before and after!
- EXHAUST: 4cyl. glasspack (corey please read)
- FU: Clutch/throwout bearing/starter contact
- Pics of RB BL and Sliderz installed
