1987 P/U, Brake Rotor Removal
Old Jul 1, 2004 | 03:31 PM
brendonv's Avatar
HOW DO U GET THE BRAKE ROTORS OFF THE FRONT??? please help as sooooooon as possible!!!
THANKS!!!
1987 Pickup, 4x4, Manual locking hubs--
Old Jul 1, 2004 | 07:05 PM
growinseed's Avatar
For an '85 4x4 you have to remove the axle hub then separate the rotor from the hub there are two bolts that hold the rotor to hub tighten to 34 ft-lbs on reassembly
HTH
Cheers
Nathan
Old Jul 2, 2004 | 03:33 AM
brendonv's Avatar
anyone else with pics or anything?? when i take my hubs covers off there is a large nut, does this have to come off???
Old Jul 2, 2004 | 04:13 AM
LCruner's Avatar
Rotors
tHERE ARE ACTUALLY TWO LARGE NUTS...AND A LOCK WASHER THEY BOTH HAVE TO COME OFF. ALSO DID YOU GET THE HUB OFF. THERE ARE CONE WASHERS AND THEY ARE A BEAR TO GET OFF....YOU NEED TO USE A BRASS ROD AND A HAMMER TO LOOSEN THEM....I DID THIS JOB A COUPLE OF WEEKS AGO ON MY 87 4RUNNER...GOOD LUCK
Old Jul 2, 2004 | 04:18 AM
brendonv's Avatar
do u know the size for the large nuts by any chance?
Old Sep 11, 2004 | 06:49 PM
ohioyotaguy's Avatar
I just ordered a hub puller from http://www.hendrixmotorsports.com/_wsn/page3.html Should be arriving any day now. I hear it makes the cone washers a snap to deal with. Good luck. By the way, the hub puller was only $19.95 + $9 shipping. Less than $30. Scroll down the page to find it.
coreyedwards7611
Jan 16, 2016 06:38 PM
Sep 4, 2015 09:27 AM
rondogracing
Jul 14, 2015 07:00 PM
87turboPA
Jul 12, 2015 07:49 AM
shar
Jul 9, 2015 12:38 PM
