my 4runner is dead!!! Help!
Old Jun 30, 2004 | 01:02 PM
SBeckner80's Avatar
I've got a 94 4runner V6, and this is what its doing.
I have no accessory (interior) electricity. Period.
I can't turn it over (no noise whatsoever when I turn the key). I have no clock, no radio, no power locks, no windows. Headlights work.
If I push start it the engine starts, but the above things still don't work. Gauges dont work either I think (showing no amps from alternator). Engine itself purrs nicely, drove it around block.
Battery is new optima and has full juice. Battery connections are good. Under-hood fuses are all good.
help!!!
Old Jun 30, 2004 | 01:20 PM
radrex's Avatar
I'd be looking real hard at your Key Switch and the connector. The lights bypass the switch.
Old Jun 30, 2004 | 01:26 PM
rbmc's Avatar
Try this site
Try this website it may have some information that may help you...?
http://www.autoshop101.com/
Old Jun 30, 2004 | 04:29 PM
87 4runner's Avatar
you figure it out ?
Old Jun 30, 2004 | 06:20 PM
SBeckner80's Avatar
still no clue, im lookin thru the shop manual preparing to rip it apart :-(
Old Jun 30, 2004 | 11:23 PM
Mystickal's Avatar
Do the interior lights work?
If so, then I'd bet that it's a relay under the hood.
~Bill
Old Jun 30, 2004 | 11:38 PM
PhxTRDRunner's Avatar
Check your main fuses (fusable links)...start testing power at your battery and work back until you no longer show voltage. Easy as that.
Old Jul 2, 2004 | 11:51 AM
SBeckner80's Avatar
Talking
thanks guys, I figured it out.
I had a feeling it was the fuses, so I started checking them with my circuit tester and found my 40-amp fuse wouldn't close the circiut, and it was blown way off to the side (couldn't see it until I broke it apart).
Yay
Colington
Mar 8, 2020 09:51 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
