- I notice this noise with newly installed rotors and brake pads...
- Removing Harmonic Balancer/Crankshaft pully
- Tacoma Rear Shock Torque Specs?
- 01 Questions, Tires, Wheels, Lift
- Tjm-17
- starting problems
- What about the wheels for me
- Electric locker indicator switch
- TSL's Around Town?
- Painting Limited Wheels
- shopping for a 2000 4runner
- Diff Spacer Issue.
- Tried to replace Brembo rotors...big problem!!
- Need advice on tire size
- Replacement rotors?
- Supercharger Pulley PSI Questions
- 3.4 timing belt parts list
- Any 3rd gen 4Runner owners have 4th gen wheels on your truck?
- Super charger or I force V-8?
- Still getting bad gas mileage after tune up
- 97 2.7L 4Runner, change timing belt?
- Requesting Pics of 99+ limited or SR5 with no rear mudflaps
- Load support
- Battery Leaking in 2000 SR5
- Screaching Belt
- Timing belt estimates.
- I've got a vibration at idle? Any ideas??
- Backspacing - LC rims
- Need some pics please help!
- Tranny and front wheels locking up on '98 2wd when on ice
- Catalitic Converter Suppleir
- 98 Tacoma starter continues to run
- 650.00 dollars later......
- misfire on #2 and # 5
- 98 tacoma 4x4 Wet carpet
- [4Runner] Why do we have drums in the rear?
- 16x7 4runner rims?
- upgrading to leather seats
- Wónt start while hot.
- Clutch Problems
- Gas Mileage on 2000 4Runner
- Another camper top sleeping platform design!
- Info needed on wiring fog & driving lights into OEM system
- Boring Out Aluminum Wheels
- vibration and rpm drops
- Boring wheels to 108 mm
- Lifting
- Very Strange Braking Problem
- E-locker not engaging :help:
- Good source for factory service manuals
- Suspension for 99 springs
- Will Wheelers 15" wheels clear tundra brakes?
- Front end noise -Already searched
- 3.4L Engine Trouble. . .
- Axle won't slide back in!
- downgrade 16" to 15" rim?
- Bed length?
- new shoes on my 4runner
- ADD Relay...Where is it?
- Wheels for wheeling? Steel Vs. Alum. & fit on 1996 Taco
- Softer Ride
- used 4r comparison opinions...
- possible tacoma bumper swap
- Dilemma: I have both 231mm and 199mm calipers, what to use...
- Just some pics!
- Getting Nokian Hakka LT's; anybody have pics of 235/85/16's on a 3rd gen?
- Battery opinions?(Hawker Odyssey, Exide Orbital)
- Vibration at high speed.
- how much for 93-98 non turbo supra injectors?
- Pinging/Fuel/Plugs
- PP Springs vs. OME 906 ???
- 4:30 gears for a TRD Diff?
- replace fuel pump 98 4runner
- water leak
- Found a crack/hole in intake above filter!
- 5VZ-FE and top-end power
- What to do with leftover cv
- body lift steering help
- I need Rear Bumper End Passenger Side for 2001 4runner
- Do I need alignment Service for my 2001 4runner?
- something is hitting my front skid plate or the likes
- Need Info: Supercharger engineering analysis
- 1999 4Runner Won't Start
- 1" body lift enough Opinions?
- 3rd Gen Owners...Post Pics of Your Double DIN In Dash Navigation...
- 97 4runner, upgrade to chrome bumpers
- What is this part?
- 2000 4Runner trailer running light trouble
- Valve Cover crack
- 3rd Gen Fire
- trailer hitch clearance
- 96 Tacoma Alarm System
- tires and alignment
- What's a normal 5ZVFE coolant temp?
- Engine removal....who has done it??
- Gas milage terrible in cold snap
- 33's w/o a BL?
- Brembo Flat Rotors and OEM Pads
- OME suspension installed, pics...
- Bigger gas tank for 3rd gen?
- 2000 4rnr with a PO420 code..
- Why is a rear TrueTrac bad for snow/ice?
- Gibson exhaust installed- and ????
- 99-02 Headlight upgrade
- Battery Discharge warning light!
- installing new supra injectors today
- High RPM Idle Failure
- What causes my 3.4 v6 to NOT rev High on cold start up??
- flipping hitch
- Valve Shims needed for 98 3.4 V6
- Body lift and 315's are on! !!Now with pics!!
- Has anyone put herculiner on wheels
- 97 runner suspension
- 96 limited axle wrap
- Looking for some 3.4 engine spec info.
- Charcoal Sequoia wheels on 2000 4runner PICS!
- How bad do 285s rub w/no lift
- Replacing a Shattered Rear Window
- Severe Studdering and Poor MPG
- Aftermarket Intake and Running Lean?
- p0171 with pending p0420
- '02 4Runner and a Diff Locker?
- Body lift 9-10 brackets
- Realistic mileage life expectancy out of my 2001 engine and tranny...
- AC condensor on a third gen.
- Rear Control Arm Mount Problems
- got my unichip and jba headers and exhaust
- 100k mi and routine maintenance
- Headlights Not coming on
- E-Locker Mod Trouble Shooting
- cut fender flares for a 3rd gen?
- Help! Installing ome leaf springs on 04 Taco
- automatic or manual
- Fixed the brake prob!! now i got a "clunk"
- 3rd generation headers?
- unichip and exhaust questions
- Source for Fender Flares?
- Running Really Rich!!
- Lifter tick
- 04 Taco RR Diff and ABS Light on for no reason - Need Help Please
- September 2006 4-Wheel and Off-Road
- Trimming rear SR5 flares
- Ignition Switch
- Vibration occurs when braking while going 30+ mph
- PP 1" spring avalibility
- '97 4runner auto transmission sticks?
- Irbis bumper pics
- cruise shuts off using signal lights
- what do i need to clear 35s on my 3rd gen
- 3rd gen. rear aftermarket shocks for lift
- Helping a buddy decide on a t4r
- Winter tires/wheels: less backspacing for wider stance?
- Wiring Question
- Question about off raod tire performance
- TRD tacoma shocks
- Another reason to upgrade your injectors if you are SC'd...
- 96 taco 2.7L P0141 P0401
- Does anyone have wood grain with the stock gray interior?
- Suggest gasket material leak around O2 sensor flange
- Can't find a DRL disable thread for me
- Purchased MAF on Ebay. THink I got scammed
- Weekend Herculiner Project COMPLETE
- Glow packs and cat convertor problem
- NeeD Help S/C Bracket
- Skid Plates on a 1999 SR5 4Runner
- Possible Transmission Problem?
- ac fan/motor kaput
- 2 inch difference in clearance from driver to passanger side?
- Alternator woes
- 15x7 rims
- lift encounter
- Aftermarket seat options
- PICS: Installed my TJM-17
- Anyone have a pic of a 1" body lift without a bumper bracket???
- 285's on my 98 3.4L 6cyl 4wd w/ 2.5 lift???
- How can I tell which alternator I have?
- your thoughts on a new ride (4r)
- 4WD won't disengage
- Just installed tundra/ome lift...needing input about a few issues.
- S/C pulley ect.
- Lifting gas tank
- 2000 4R Running very rough when cold
- Cv axles interchangeable
- 150K trans fluid change
- ISR Deckplate Trueflow. WOW
- Fuel Type?
- 3rd gen Adjustable Trac/PanHard Bar
- Towing Question
- CV axle swap
- Surco Rack owners with light brackets
- 199mm Caliper Rebuild Kit P/N
- Weld wheels on a Toyota?
- Brake problems
- Strange Noise
- Coil Over, LIKE SWAY AWAY
- Transfer Case Seals
- Fluids
- Rotor Choice
- Another just lifted thread. . .no 56k!
- TJM Install Question on 1997 4Runner
- How long after dc battery OBDII Ready
- Tacoma Temp Guage
- Driving with 295s
- Going from E-Locker Diff. to Open Diff.
- tire question
- Engine missing and bad gas milage
- Rear diff. leaking oil from behind left brake
- Water in A-Pillar?
- Ignition Swtich replacement
- 4WD indicator light not working
- Help me find my OBD-II port 1999 4rnr
- ? about oem fogs,hellas,and wiring in prep for my TJM
- Are the stock 4runner top plates acceptable for tundra coils?
- Gained 10 HP and lost 10 HP...
- Brakes problem - I'm ready for an upgrade
- which fpr am I using?
- URD/Walbro 190lph fuel pump installed!!!
- Tundra/LC coil lift w/265-75-16's
- Finally got some pics of my rig today!
- strange noise coming from front driver side wheel
- Fog Lights problem '97 4runner SR5
- New Member To The Family
- Walbro 190 LPH fuel pump break in period?
- Replacing headlight bulbs
- Should I buy these coil spacers?
- Steering wheel jerks over bumps but no excessive play
- Block heater question
- Light bar options
- LC Coils on 3rd generation
- Starting problems, starter or battery or ???
- Clutch pedal assembly / master cylinder replacement part woes (faulty parts? pics)
- Water Getting into Coil Packs?
- Question about Trekmasters and Tundra coils
- Tacoma TRD windoww tint question
- Are my headgaskets going?
- New shoes for the Tacoma!
- Were is the automatic neutral switch located
- Power programer for Toyota 3.4
- Do i have a susp lift?
- About to start the Tundra lift and there's a problem
- Broken fan clutch pully? How bad is it?
- Throwout bearing sticking?
- Axle Leak
- Throw-out Bearing Squeek (Fix??)
- Is there any interest in a COMPLETE S/C setup?
- Seperating rear axle shaft from drum?
- Heater diverter problem
- MPG difference observations between gas stations.
- After Cat O2 Sensor Question...
