E-Locker Mod Trouble Shooting
Old Oct 18, 2006 | 04:21 PM
Elton's Avatar
for some reason i cant get it to work i used this write up and all it does is blink and it does have a good ground heres a pic of the wire i cut and grounded
Old Oct 18, 2006 | 09:11 PM
Elton's Avatar
no one ?
Old Oct 18, 2006 | 09:40 PM
black runner's Avatar
which safety option are you trying to disable???
I used phongs write up to wire mine, but left both safety options on.
http://www.sonoransteel.com/phong/re...ic_locker.html
Old Oct 18, 2006 | 09:57 PM
Elton's Avatar
i want to be able to use it when i need it instead of 4lo and all its says it to ground the blue/red wire wich i did ? but it dont say anything about it blinking
Old Oct 18, 2006 | 11:31 PM
d0ubledown's Avatar
when you tested it..did you try moving forward/backward to engage the lock or were you stationary? hows your ground connection? i think blinking means its on/trying to engage. not blinking/solid on means locked/engaged...
Old Oct 18, 2006 | 11:40 PM
Elton's Avatar
i tryed goin up a small grassy hill and it just spin one tire so its not working and it dont work in 4lo my spot for the ground must be a bad spot or something its in the same spot as in the writeup
Old Oct 19, 2006 | 04:46 AM
fireteacher's Avatar
bare metal?
Old Oct 19, 2006 | 02:02 PM
Elton's Avatar
yea i sanded down the paint
Old Oct 19, 2006 | 02:24 PM
hmm, 100% correct wire? i would try a diff ground if you think its suspect
Old Oct 19, 2006 | 02:30 PM
04 Rocko Taco's Avatar
still working at it, Eh, Elton? Good luck man! I'd come over and help ya out if I wasn't....oh, 2900 miles or so from you. lol.
Old Oct 19, 2006 | 08:17 PM
Elton's Avatar
well ill move the ground and see if that helps and it dont work in 4lo so i know its not working
Old Oct 21, 2006 | 05:14 PM
BruceTS's Avatar
grey wire mod is only for Taco's, on 4Runners I believe it's blue with a yellow stripe....... been a while since I've looked at the wiring......
Old Oct 24, 2006 | 04:11 PM
Elton's Avatar
well i moved the ground and still blinks it has a good ground im sure some on knows what im doing wrong
Old Oct 24, 2006 | 04:18 PM
elton, for some reason i remember this referred to the gray wire mod also. i cannot remember which color the wire was but ill go out and check it to make sure.........
Old Oct 24, 2006 | 04:19 PM
Elton's Avatar
all ive heard its its blue and red
Old Oct 24, 2006 | 04:23 PM
ok, just checked and it is a blue wire with a red stripe so you got the right one!
Old Oct 24, 2006 | 04:27 PM
only thing i can think of.....
did you remount the box? maybe it needs to be grounded. in the pic, you just have it hanging there.
i just unplugged the connector and left the box in there when i did it.
if you have some long wire, just run it to the battery to make sure it works or dosnt. other than that.....?
it still wont work in 4lo since you re-ground it?
Old Oct 24, 2006 | 04:30 PM
Elton's Avatar
the pic is from a different thread i just used it and it dont work in 4lo ...any pics of urs ?
Old Oct 24, 2006 | 09:39 PM
Elton's Avatar
anyone else want to add something also i did ground the wire going to the locker and not to the box
Old Oct 25, 2006 | 01:10 AM
AH64ID's Avatar
Are you sure it worked before??
Check all your fuses...
So now its back to OEM wiring and still doesnt work?
Just re-read your last post, you need to trick the box not the locker....
