E-Locker Mod Trouble Shooting
Old Oct 25, 2006 | 08:08 AM
fireteacher's Avatar
Originally Posted by Elton
anyone else want to add something also i did ground the wire going to the locker and not to the box
you need to ground the box and not the locker!!!!!!!
Old Oct 25, 2006 | 08:13 AM
mastacox's Avatar
X2
That's why it isn't working. I think the other side goes to the T-case to sense if you're in 4-Lo, when the case is in 4-lo the wire becomes grounded.
Old Oct 25, 2006 | 12:36 PM
Elton's Avatar
Originally Posted by AH64ID
Are you sure it worked before??
Check all your fuses...
So now its back to OEM wiring and still doesnt work?
Just re-read your last post, you need to trick the box not the locker....
worked fine before and its still grounded not back to stock all fuses are good
Old Oct 25, 2006 | 12:37 PM
Elton's Avatar
so i have to ground the wire that plugs into the box and not the wire that go's some where ?
Old Oct 25, 2006 | 12:52 PM
  #25
Yeeeaaaahhhh!!!!
Old Oct 25, 2006 | 12:54 PM
  #26
AH64ID's Avatar
Yes, you are trying to fool the box, not the locker. The box is what controls the locker....
Old Oct 25, 2006 | 01:13 PM
  #27
Elton's Avatar
well ill go switch it around
Old Oct 25, 2006 | 01:17 PM
  #28
:pat:
Old Oct 25, 2006 | 01:47 PM
  #29
Elton's Avatar
you guys are great it works now :bigclap: ... no thanks to the crappy writeup now when someone has the same problem they well find there answer
Old Oct 25, 2006 | 01:49 PM
  #30
mastacox's Avatar
Another crisis averted. Glad you got it working
Old Oct 25, 2006 | 01:52 PM
  #31
Elton's Avatar
ya someone needs to make a better writeup
Old Oct 25, 2006 | 02:00 PM
  #32
mastacox's Avatar
I nominate you!
Old Oct 25, 2006 | 02:11 PM
  #33
da_bigg_wigg's Avatar
Originally Posted by mastacox
I nominate you!
Considering you have the most experience on what not to do
Old Oct 25, 2006 | 02:25 PM
  #34
i thought bob had one but i cant find it...guess he doesnt!
Old Oct 25, 2006 | 02:29 PM
  #35
Elton's Avatar
ive only found that one and hours of searching didint help go figure
Old Oct 25, 2006 | 02:31 PM
  #36
elton, maybe you nuked it! in his write up, #4 states
"Give yourself 2 or 3 inches of slack on that wire FROM the white harness, just in case. Cut the wire and bring out the soldering gun. Tape off the wire hanging down from nowhere. Solder the wire coming out of the white harnass to an extension wire, which you will be grounding."
the pic below shows how you should of done it! Slow down next time you free mod grubbin @$#%$
non the less, glad you got it fixed...finally! maybe if you made a write up that clearly states the correct way to wire the box, bob will put it on his site and in the off road enhancements
Old Oct 25, 2006 | 02:34 PM
  #37
Elton's Avatar
lol i did look at that and if it says ground the wire going to the box that would of helped
Old Oct 25, 2006 | 02:36 PM
  #38
sigh....."Solder the wire coming out of the white harnass to an extension wire, which you will be grounding."
geez!!!
maybe yuo aer bettre of raeding liek this. i bet yuo were drniking!
Old Oct 25, 2006 | 02:40 PM
  #39
Elton's Avatar
no alcohol for me im only 20 one more year
Old Oct 25, 2006 | 06:11 PM
  #40
well since you werent drinking, these guys are having a sale!
http://eyeglassworld.imswebmktg2.com...que/88730.php?
