starting problems
Old Oct 31, 2006 | 02:43 PM
tacoonjuice's Avatar
starting problems
i have a o1 tacoma and i am having trouble with my truck starting. it will start for a second and die. if i leave the key in the on position for 45 - 60 seconds it will start just fine. after it starts it runs perfect, its just getting it started. if you have any suggestions that would be greatly appreciated
Old Oct 31, 2006 | 03:03 PM
bruizer's Avatar
maintence
chg. the fuel filter...............test the pump.
Old Oct 31, 2006 | 04:12 PM
i have checked and replaced both, could it possibly be my sending unit or my efi relay
Old Oct 31, 2006 | 05:29 PM
also my check engine light is not on, if i hook it up to a diagnostic will it still through a code
Old Nov 1, 2006 | 10:46 AM
Tanto's Avatar
It may be *pending* a code, meaning the ECU is getting errors but it's waiting until it gets those errors X times before the light kicks on.
An OBD II reader will pick up pending codes.
Old Nov 3, 2006 | 03:15 PM
alotawatts's Avatar
Originally Posted by tacoonjuice
Couldit be my sending unit or my efi relay
Fuel Injection Relay - Definately worth checking. Bad relay is often a no-start at all too.
Old Nov 3, 2006 | 03:42 PM
Amby's Avatar
Do you have an alarm? I had a problem like that on my 4Runner and it turned out to be my alarm. It was all messed up. I didn't even have the remote or anything.
Just a thought.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
