Body lift 9-10 brackets
Old Oct 19, 2006 | 07:08 PM
Localmotion's Avatar
Does anyone run the 1" bodylift w/o the 9-10 mounts on thier 96? I plan on installing mine this weekend, but will not be able to get the 9-10 welded on immediately. ANyone know if this is unsafe?
Old Oct 19, 2006 | 07:12 PM
KyleT's Avatar
i didnt put mine on and havent noticed any issues.
it doesnt ride any different now or anything. just be sire to torq down the bolts good or it will move. and take the lower rad shroud off before you start the engine.
Old Oct 19, 2006 | 07:16 PM
lower radiator shroud? Lookslike im gonna have to read the directions again. LOL
Old Oct 19, 2006 | 07:18 PM
KyleT's Avatar
yeah i missed that one. not sure if i was suposed to take it off, but it made hella noise when i started it. the fan was rubbing into the shroud. it came off in 2 seconds with 2 metal clips that hold it on. (i didnt have any instructions to go by, just reading up on here..)
Old Oct 19, 2006 | 07:23 PM
BajaRunner's Avatar
I have had mine on (2") for about a year and a half, and its okay.
I'd certainly feel a lot better If I had the mounts welded on though, but, Im just a lazy POS.
Old Oct 19, 2006 | 07:28 PM
LOL, I just dont have access to a welder...and I am a lazy POS like you. Should I just stick the 9-10 mounts on and have someone weld them on later? Will it work like that?
Kyle, do you have a write up/directions to the fan shroud thing? I cant find it on the instructions.
Did you guys just use a hilift and jack off the body...heh heh hehhh
Also, how do you get the front in the air if you have TJM? Sorry for the million questions, i just want to make sure I have everything down.
also, anyone have the torque specs?
Old Oct 19, 2006 | 07:35 PM
KyleT's Avatar
no, i just pulled it off, the bottom half is a half circle piece, has a metal clip on each side. and fits in a tab on the bottom. took 2 seconds to take off.
mahe sure to use a long 2x4 (3ft or so) on the pinch weld to jack it up.... i didnt and have a dented pinch weld now....
as far as torque, i guestimated the weak number that everyone suggests and it moved, so i took the impact to it and hit it till they didnt move any more. i hit and let off, not just one constant on, i didnt want to break them.
the body literally shifted 2" to the drivers side. i could feel it was off. i should have taken a picture of the mounts all canted sideways.
Old Oct 19, 2006 | 07:37 PM
KyleT's Avatar
all in all it was not a fun project..... it sucked really.
Old Oct 19, 2006 | 07:38 PM
awesoem. BTW...are you rubbing with just 1" BL and 295s?
Did you install the steering extnesion or just ass washers?
again, thanks for the quick responses..I'm becoming paranoid.
Old Oct 19, 2006 | 07:39 PM
not what I like to hear..lol
Old Oct 19, 2006 | 07:46 PM
neliconcept's Avatar
me neither cuz I want this to go pretty clean. my 2 inch is going on along with his 1 inch in the same day
Old Oct 19, 2006 | 07:48 PM
JGM's Avatar
JGM
I put my 1" RB BL on in a couple hours. I didn't think it was a bad job at all. I would not use a highlift - I used a couple of hydraulic floor jacks with a chunk of 2x4 to spread the load on the pinch weld. I had to lift it further than I thought at first to separate the body from the frame, but once I did one side, the other went smoother. All in all, not big deal. Just take your time, and double check that everything is loose.
KyleT's Avatar
yeah put the steering extension on. yes i rubbed. the rear bumper, the pinch weld, nearly took the fender flair off, hits the pinch weld, had to trim the front bumper and front flair piece. It doesnt rub on the street, but off road i took the f and r bumpers off. I nearly took off the fender fairs on the front, and ended up ripping out one of the front fender liners. a 1" is barely enough. i need to bang the pinch weld and trim the front flairs a little.
Old Oct 19, 2006 | 07:49 PM
KyleT's Avatar
you will definately do better with 2 people.
Old Oct 19, 2006 | 07:50 PM
KyleT's Avatar
oh dont lift the drivers side too far as you can rip out the fuel tank wires, and take the fuel filler loose as it will stretch a little. 2" might need an extension. not sure though.
Old Oct 19, 2006 | 08:01 PM
waskillywabbit's Avatar
On a 2" body lift on a 3rd gen the only thing you need to check/loosen are the bumper mounts on the sides where they attach to the body, the battery cables and the fan shround. Get a steering extension too. For a 1" body lift, not much to it. No body lift should take too long or be that much trouble, even alone...if you bother to read the directions.
Old Oct 19, 2006 | 08:14 PM
KyleT's Avatar
I didnt get instructions.... all i got was a box full of parts.... bought it second hand, not used but no papers what so ever..... plus i was in a hurry.... it was a bad deal for me none the less.
Old Oct 19, 2006 | 08:17 PM
Instructions are on www.4crawler.com and all over
Old Oct 19, 2006 | 08:20 PM
KyleT's Avatar
bah. i know that now...
Old Oct 20, 2006 | 05:22 AM
thanks for the advice guys.
