Body lift 9-10 brackets
Old Oct 20, 2006 | 07:19 AM
BajaRunner's Avatar
Well, just to make you feel better, it was fairly easy/fun/straight-forward for me.
Pretty much anything I do, I run into some snag, and get mad.
The body lift, went smooth for the first time. Did it by myself in about 3-4 hours.
I used a regular floor jack with a few 4x4's (cut to about 8") stacked and lifted the body off the frame.... actually, im lying, I used 3 old broken surfboards underneath the jack to get it higher...but, if I were to have the 4x4's I would have used them.
Just need to take off the inner lining, hold the top of the bolt, and turn the bottom side at the same time kinda is awkward but doable.
Old Oct 20, 2006 | 07:28 AM
neliconcept's Avatar
me and Matt should get both our trucks done in 5-6 hours probablly..
I have plenty of spare wood and a floor jack. should be fun, never installed a bodylift but it cant be that hard.
Old Oct 20, 2006 | 07:43 AM
4Crawler's Avatar
Originally Posted by Localmotion
LOL, I just dont have access to a welder...and I am a lazy POS like you. Should I just stick the 9-10 mounts on and have someone weld them on later? Will it work like that?
Kyle, do you have a write up/directions to the fan shroud thing? I cant find it on the instructions.
Did you guys just use a hilift and jack off the body...heh heh hehhh
Also, how do you get the front in the air if you have TJM? Sorry for the million questions, i just want to make sure I have everything down.
also, anyone have the torque specs?
You can bolt on the body mount brackets with the supplied self tapping bolts:
- http://www.4crawler.com/4x4/ForSale/...yMountBrackets
Then, once in place, you could have someone weld them on at any time.
Fan shroud details:
- http://www.4crawler.com/4x4/ForSale/...ToyotaRadiator
Ideally you want to place the jack near the center of balance of the body to lift both ends evenly. Floor or bottle jack under the floor with some wood blocks work well:
http://www.4crawler.com/4x4/ForSale/...l#Installation
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Cabell
Jul 24, 2015 12:14 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
