3.4 timing belt parts list
Old Oct 31, 2006 | 06:05 AM
Ironmike4x4's Avatar
YES I've searched and came across this thread... https://www.yotatech.com/forums/show...crank+seal+3.4.
Here's the list of what I'm ordering so far...
timing belt
water pump
cam seal
thermostat
upper radiator hose (mine is leaking now)
My question: is the crank seal available for the 3.4l on this website? http://www.trademotion.com/partlocat...?siteid=214074
The only one I can find is for the 4cyl models. Anything missing from my list?
Old Oct 31, 2006 | 06:13 AM
habanero's Avatar
Besides your list I got:
The tb tensioners (except the hydraulic one) from the dealership in case I needed them. I did that so I could return what I didn't use.
Also got belts, all hoses and antifreeze.
And some blue loc-tite because I wrench like a girl.
Old Oct 31, 2006 | 06:54 AM
boogyman's Avatar
make sure you have a torque bar that can handle the job too.. you have to torque 1 bolt to something like 220 or 240 ft/lbs.
Old Oct 31, 2006 | 08:36 AM
I'll have all of the tools necessary from my own former mechanical career; hoever, I'm having a buddy of mine I went to GM mechanic school with who is now working for a Toy dealer to help me with it. I mainly need info reguarding the crank seal from the toyotaparts website. I cannot find the right link to get one other than the 4 cylinder crank seal.
Old Oct 31, 2006 | 10:55 AM
surf4runner's Avatar
dont forget cold beverages
try nothridge toyota(search) for the seal
Old Oct 31, 2006 | 03:29 PM
My search result...http://www.trademotion.com/partlocat...del=4%2Drunner
Old Oct 31, 2006 | 07:08 PM
youngbuck's Avatar
I am ordering all of my T-belt parts from strap22 (PM him on this forum) who is at Toyota of Dallas. Probably the best prices for OEM parts. He also has another name on this sight, which I believe is trdparts4u.com
If you don't wanna go through him, check out Northridge Toyota, which also has an employee that is a popular member on this sight (I think his name is northridgetoyota on this sight).
Old Nov 1, 2006 | 04:29 AM
MTL_4runner's Avatar
Mike, I honestly wouldn't worry about the cam/crank seals if this is your first T-belt you're doing on the truck. The Honda and Toyota seals from the factory are very good quality and as long as the vehicle has had the oil changed fairly regularly and the motor hasn't been overheated, the seals should be in good shape until your next timing belt (at that time I would probably consider doing them). Just my $0.02 anyway.
Old Nov 1, 2006 | 01:14 PM
vegaskurt's Avatar
^^ I agree, unless the cam seals are leaking dont worry about them.
When I did mine I also replaced the upper idler pulley and the other idler that the tensioner pushes on. One of them (cant remember wich) was making noises.
Old Nov 1, 2006 | 01:36 PM
Normally I wouldn't worry about it, but I already have 127K miles on it and am not sure of the previous owner's record history.
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
layifioren
10
Jul 6, 2015 02:26 PM
crazypaint
Jun 23, 2015 03:27 AM
infinityisfive
Jun 16, 2015 06:51 PM
