150K trans fluid change
Old Oct 12, 2006 | 10:56 AM
mark_simon's Avatar
I had a trans flush done @60K and nothing since. Everytime I go for an oil change toyotas tells me that the trans fluid is fine. Was wondering if I should get another flush or do a regular change and clean/replace filter, drop pan ect..
Old Oct 12, 2006 | 10:31 PM
Elton's Avatar
pretty sure i got 137k on stock fulids and well over 167k on my other 2 toyotas ive owned
Old Oct 13, 2006 | 01:48 AM
AH64ID's Avatar
Fluids, espically non syntheitic, are not desigened to go that long. They brake down and dont do what they are supposed to. Espically ATF, if it gets hot once its done...
My reccommendation... have it changed.. if you run dino fluids every 30K like the manual says.. or you could step up to amsoil ATF and only change it if it gets hot..
Old Oct 13, 2006 | 03:01 AM
Potomacduck's Avatar
I would flush it, that's the only way to most of the fluid out.
As for my truck, I drain the pan at every 5,000 mile oil change. It drains about 5-6 quarts (about 40% of the total volume) each time.
Old Oct 13, 2006 | 03:03 AM
Localmotion's Avatar
i would do the fluid exchange. I was in the same boat as you, except I did mine at 90k..and the next time I did mine was at 220. Tranny shifts a lot smoother.
Old Oct 13, 2006 | 06:53 AM
TheDarkKnight's Avatar
I think the Toyota "recommended" is every 30k.
My oil change guys suggests every 60k.
At 180k, I have changed mine twice. (Second time was @ approx 170k. The shop did not want to flush, and the couplings that they wanted to connect to flush are rusted on, and they were not willing to risk breaking it).
my 2bits
tdk.
Old Oct 13, 2006 | 07:02 AM
KyleT's Avatar
what is the best method for the fluid exchange? i have been putting mine off because i could never find any info on this.
Old Oct 13, 2006 | 07:05 AM
http://www.gadgetonline.com/TransFlush.htm
I did the first one, as the second one was unavailable to me.
Old Oct 13, 2006 | 08:20 PM
mark_simon's Avatar
toyota in my area has a special for there flush for $89 but I am wondering if I need to drop the pan and change the filter since this has never been done?
Old Oct 13, 2006 | 08:34 PM
you can...I didnt. Im still clear...LOL.
89 isnt bad for a flush..i would do it from them!
Old Oct 13, 2006 | 08:37 PM
CJM's Avatar
CJM
The owner I got my truck form was a maintinence freak b/c he hauled a boat a few tiems a year. Thus I have a tow package with the trans cooler and he changed his ATF every 10-15.
Imho about every 20-30k is fine, now only if it was as easy as changing oil.
Old Oct 14, 2006 | 02:15 AM
AH64ID's Avatar
Have a service shop change the filter and flush it, bring AmsOil to the service place for the refill during the flush.. forget about it.. for at least 3 years...
Old Oct 14, 2006 | 07:05 PM
Tacos4me's Avatar
Has anyone tried "redline MT90" synthetic?
Old Oct 15, 2006 | 04:50 AM
ohio4runner4x4's Avatar
Talking
I'm getting ready to change the filter and do the flush using the tranny's own pump.....I'm at 150k and not sure when it was changed last?
from all my searching....this sounds like the best method for high mileage trans fluid...
Old Oct 21, 2006 | 06:12 AM
FredTJ's Avatar
Yes, the whole Redline product line is second to none.
Note, thought, that the MT90 is NOT autotranny fluid, it's a 90wgt for
MANUAL trannies.
Redline does make a whole lineup of synethic tranny fluids.
BTW, also change the filter when the fluid is changed.
You wouldn't think of changing your engine oil without changing the filter,
would you ?
Fred
Old Oct 23, 2006 | 02:55 AM
AH64ID's Avatar
20 quatrs = 5 gallons... seems a bit much for a tranny flush.. my dad usually takes in 5 gallons for his 4L80E (454 auto tranny), and gets about 2 gallons back.
But anyways.. .5 gallons of amsoil is 162 bucks +tax/shipping... and good for 60K-100K miles. 5 gallons of normal ATF is $100 and good for 30K... hmmm more up front, less over all and better for the tranny??
psss... I am an amsoil dealer, I could probally get it to you for about 160 to your door, thats about 15% OFF..
As far as flushing goes... cant you do a home flush by disconnecting the cooler, puting the return in the fluid and the other end in an old bucket? Jack up the rear and kick in in drive? I guess you would still want to change the filter thou....
Old Oct 23, 2006 | 07:06 AM
4Runner4Christ's Avatar
I would also recommend the flush method Gadget has on his site. I also believe the pan should be dropped and inspected as that is the only true way to judge the health of your tranny. There are also magnets in your pan that attract metal and need to be cleaned off.
Old Oct 23, 2006 | 10:01 AM
AH64ID's Avatar
I havent seen his site, I was just wondering how you can do it without a machine.. i'll check it out..
Eggslinger
Jun 8, 2019 03:32 PM
Up&Down
Aug 11, 2015 10:04 AM
the1998sr5
Jul 16, 2015 06:20 AM
Poncho0206
Jul 10, 2015 06:21 PM
