water leak
Old Oct 24, 2006 | 04:53 PM
toyotaoffroad91's Avatar
water leak
i noticed today while my buddy was driving my truck and i was in the passenger seat that i have a water leak right above the passenger sunvisor. if i stick my hand up there between the roof and the headliner its wet. my first guess is that the sun roof is leaking. ive checks the drains up there and they dont seem to be blocked. have any of you had expierence with this. BTW its a 96 4runner limited.
Old Oct 24, 2006 | 05:18 PM
mpavolka's Avatar
Have you had your windshield replaced lately? I had a 90' 4Runner that leaked from there because the windshield was installed poorly.
Old Oct 24, 2006 | 05:40 PM
no still the oem windshield
Old Oct 26, 2006 | 06:59 PM
mpavolka's Avatar
Seeing that there isn't anything else to leak, I would guess that it is probably your sun roof. Don't know what to tell you those seals get old.
Old Oct 26, 2006 | 09:52 PM
gapboi210's Avatar
yup, can't but the seal either. Whole glass and seal have to be bought for around $591.00
Old Oct 26, 2006 | 11:15 PM
kcebes's Avatar
You can't be serious!
Old Oct 30, 2006 | 05:24 PM
CU4runnerSR5's Avatar
My 4Runner had some water stains on ceiling panel when I first got it. Turned out to be leaking from the roof rack. On the stock roof racks, there are endcaps that can be removed to reveal small holes in the roof. Normally, there are plastic plugs in the holes but for some reason mine had been removed. I think an aftermarket roof rack was used at one time. Anyways, you may want to check those four holes if the sunroof doesn't appear to be leaking.
Old Oct 30, 2006 | 05:45 PM
gapboi210's Avatar
Yup called the stealership. I have a water leak above my rear passenger door. Can't figure out where it is coming from.
gapboi210's Avatar
Can you clarify this some more. Where do I look?
Old Oct 30, 2006 | 08:15 PM
On the driver and passenger sides of the roof rack, there are rails that run from front to back. At each end there is an endcap that is held in place by one screw(I think it is a torx, but I can't remember). If you remove the screw you can pull off the endcap. Underneath you will find a small rectangular hole. They should have plastic or rubber plugs, but mine were removed for some reason and water leaked in from there. I hope that helps.
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
jjrbus
Jul 19, 2015 02:06 PM
Jonny246
Jul 12, 2015 04:51 AM
Avenged
Jul 9, 2015 07:55 AM
