3rd gen Adjustable Trac/PanHard Bar
Old Oct 11, 2006 | 07:06 PM
ROOFGOOF's Avatar
Anyone using the Adjustable Trac/PanHard Bar from Sonoran Steel ? Reviews/comments?
Thanks!
Old Oct 11, 2006 | 07:20 PM
ecchamberlin's Avatar
I now spaugh (Brad) has one. Maybe PM him.
Old Oct 11, 2006 | 08:47 PM
KyleT's Avatar
i got the drop bar from him, easy, just bolts on no adjustment.
Old Oct 12, 2006 | 06:48 AM
sschaefer3's Avatar
I don't think there is much to review, it is a tube with ends that screw in and out.
:rockband:
Old Oct 12, 2006 | 06:56 AM
ROOFGOOF's Avatar
I was just checking...I guess the main reason of it being straight as opposed to the curved older model. (making it adjustable, I know )
Just wanted to see if anyone had it on...I will be ordering one soon !
Old Oct 12, 2006 | 07:05 AM
sschaefer3's Avatar
The curves on the bent bar were purely ascetic, that in reality was simply a longer bar.
If you changed rear lift heights with the drop bar, it was off again. With the adjustable bar, no matter what height you are at it will always be perfect. You can change your rear setup every week and adjust the bar to the correct length for every setup.
Bottom line, is that this is a huge improvement over the drop bar.
Old Oct 12, 2006 | 07:26 AM
BajaRunner's Avatar
RoofGoof, if you plan on going super high, I'll trade yours with mine. Im dropping mine down from 7 to 5 " and cant use this thing anymore!
Old Oct 12, 2006 | 07:30 AM
sschaefer3's Avatar
Now, we have to be clear here. He's talking about a custom sized "drop bar" which is not adjustable and no longer made.
"IF" we would have had at the time he ordered, an adjustable bar, Ian could simply adjust the bar shorter from 7" to 5".
Old Oct 12, 2006 | 07:42 AM
BajaRunner's Avatar
Yes, yes, very true
I should have added *sarcasam* in there... I doubt Roofgoof would want a big ol bar like mine. hee.
I cant wait to get the adjustable one! Then I wouldnt have to worry about my driveshaft hitting the gas tank under compression!! (Caused by ME ordering a bar that was too long, and then lowering the rear since it was too stiff/tippy).
Old Oct 12, 2006 | 07:46 AM
sschaefer3's Avatar
I would post it in the "for sale" section, someone will come along that jacks the back up that high.
You never know.....
Old Oct 12, 2006 | 07:58 AM
lee's Avatar
lee
im using it.. its just dandy
Old Oct 12, 2006 | 09:36 PM
pacRunner's Avatar
:rockband:
Steve...what about the load sensing valve. The pictures on your website don't appear to have this relocated on the adjustable bar. Would I have to weld this on the retain the function?
Old Oct 13, 2006 | 04:58 AM
ROOFGOOF's Avatar
Maybe we can get group pricing
Anyways, I am glad you guys are thinking of this kind of stuff...that adjustable bar is sweeeeet.
Off topic, hey Ian do you still have a BL on that thing too? Just curious.
Old Oct 13, 2006 | 05:42 AM
sschaefer3's Avatar
There are so few base model 2.7's out there that did not get ABS. With ABS you did not get the load valve. Even my 2.7 did not have the valve.
Honestly the only thing you can do is a drop bracket to level the stock bar and then a raise bracket for the attachment point of the level valve.
This bar is for the other 99% of the 3rd Gens out there. You would need to take a different route.
Old Oct 13, 2006 | 06:28 AM
BajaRunner's Avatar
Yeah, I still have a body lift. Im planning on taking it down to 1" though too.
I like the clearence between the frame and body. More room to work with.
Old Oct 13, 2006 | 06:36 AM
sschaefer3's Avatar
You still making surf boards? With Clark gone what has happened? Interesting industry to watch and see what happens.
Blamalam
Mar 12, 2022 07:34 AM
4.34runner88
Aug 11, 2018 10:44 AM
andrewtexas123
Jul 6, 2016 01:49 AM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
