E-locker not engaging :help:
Old Oct 27, 2006 | 03:46 PM
One_96TR4's Avatar
Ok so I was out in some mud today playin' around and I figured i try out the old locker. Put it in 4low and pushed the button and nothing . The rr diff lock light just keeps flashing and won't engage and go solid . I've only had the truck for about 2 months now and it's been great but this just bugs me now. Any one have any idea's what it could be and how much it would be to fix it?
Old Oct 27, 2006 | 03:48 PM
Elton's Avatar
check to see if its still pluged in tight.... you where stoped and going below 5mph and did you try backing up a few times
Old Oct 27, 2006 | 03:51 PM
ecchamberlin's Avatar
On my 99 Taco I would have to roll forward and backwards a couple of times to get it to lock up and the light to go solid. I imagine it needed to be taken apart and cleaned up.
Old Oct 27, 2006 | 04:25 PM
Elton's Avatar
also you should do the blue/red wire mod so you dont have to be in 4low its a real easy mod
Old Oct 27, 2006 | 04:47 PM
X2and4X's Avatar
Drive slowly forward turning the wheel alittle back and forth and that should allow it to lock up.
Old Oct 27, 2006 | 07:35 PM
One_96TR4's Avatar
I'll have to get under it tmw and see if I can see any loose or broken wires. The trucks in excellent shape that's why I was shocked when it wouldn't engage. I tried moving back and forth and turning the wheel and everything, nothing happens. This may seem dumb to some of you put what might need to be taken apart and cleaned? The motor? If so then where is it located. Would you recommend I try this myself or should I take it to someone?
Old Oct 27, 2006 | 07:45 PM
Elton's Avatar
so it just started doing this
Old Oct 27, 2006 | 08:21 PM
One_96TR4's Avatar
No I've only had the truck for about 2 months now and I've never actually used the locker before. I was just saying that it was wierd that it didn't work considering how well maintained the the truck was. It's also a 5spd if that changes anything.
Old Oct 29, 2006 | 05:41 PM
jjrgr21's Avatar
just do the "grey wire locker mod" it works wonders and is super easy to do.
Old Oct 29, 2006 | 06:21 PM
One_96TR4's Avatar
I probably will but i want to get it to work before I mod it to work in 2wd. No point if it won't even work in 4low! I haven't had a chance to check the connections underneath as it was a busy weekend for me. I've got a pretty busy school schedule during the week so I'll have to get under it maybe friday afternoon and see if I can figure this out. I'll let you guys know if I find anything.
Old Oct 29, 2006 | 09:00 PM
Elton's Avatar
thats for tacomas only 4runners are a blue/red wire
Old Oct 30, 2006 | 12:42 PM
2001Millrunner's Avatar
PM and ask Midiwall, i believe he had something like this happen...something about a solinoid going bad...
shisha1999
Mar 3, 2016 07:09 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
beltcutter
Sep 30, 2015 06:14 AM
zz_denis
Sep 6, 2015 03:43 PM
