Why is a rear TrueTrac bad for snow/ice?
Just spent some time searching but one thing I don't understand is why a rear TrueTrac would be bad for snow/ice. I thought the whole idea was to bias torque to the wheel with more traction in slippery conditions.
If neither wheel has any or hardly any traction (like in snow/ice) then both wheels stay locked together. This will cause it to be squirrelly (sp?) in turns or if you try to accelerate fast. That is the main reason most manufacturers use open diffs so one stays still for stability and the other spins for power (that and it's cheaper). I generally drive powersliding anyway in the snow so I don't think it'll be a big deal (I'll be running an Aussie Locker), but do know what your are doing so you don't slide the back end into something. If you use 4WD in the snow then it'll be easier to keep it from getting out of hand. If you have and LSD or locker just practice with it at the first snow in a parking lot or something and you should be fine.
It is not bad in snow and ice in my experience. I have never had problems with the rear end sliding out. I have had the TrueTrac in the rear for many years. It's not the same as an open dif, but if you know what you are doing, it's no big thing.
I have used PowerLoc, Detroit Lockers and the Eaton TrueTrac (formerly Detroit TrueTrac.)
IMHO the TT has the best street manors of the bunch.
Where it lacks is in it's offroad ability. Get crossed up w/ one off the ground or lightly loaded and that's all that'll spin.
On the street it does very well.
Unfortunatly they don't last very long. I'm on my third one now and if there was ANY other LS or locker with good street manors I'd be gone from the TT.
Are you running a gear driven Truetrac?? If its not holding up, please explain what problems you're running into.
First one got 'grindy' at about 60kmi. This due to the gear tooth surface flaking off. No assistance from Eaton.
Second one lost the bolts and wiped out the whole 3rd in 20kmi. No assistance from Eaton on this which is clearly a manufacturing defect.
To the tune of $1200All this with stock 31" tires.
Now running a 32.5" and there's little doubt the POS will die again. Hopefully it'll last long enough for me to get my LS1 project underway and ditch the whole Toy driveline.
I wish there was another LS on the market that fit the Toy, but there is not. Performance of the TT isn't stellar, but it's better than a racheting locker on the street which is 99% of my use.
Bleh, all in all, sounds like it's more potential trouble than it's worth.
That sounds like what lockers do in the snow. Maybe the TrueTrac isn't very limited in slip?
If both wheels were to lose traction, whether LSD or open, wouldn't they both spin or "lock"?
I'm still confused.
If both wheels were to lose traction, whether LSD or open, wouldn't they both spin or "lock"?I'm still confused.
Yes.
To the tune of $1200...
I'm still confused.
Is any of this helping with your question? I thought from reading all the posts it was pretty well answered...
Fred
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
icentropy
Jul 9, 2015 02:12 PM
