What's a normal 5ZVFE coolant temp?
Old Oct 23, 2006 | 04:05 PM
mt_goat's Avatar
Ok I'm new to this 5VZFE and OBDII reader, so what is the normal range of temps for you guys with a OBDII code reader or some other type of coolant temp gauge. Please state if you have a factory thermostat or not.
Old Oct 23, 2006 | 05:24 PM
Gadget's Avatar
With the stock thermostat it usually reads 190* F
You will find that it will normally be 10* higher then the thermostat temp.
Gadget
Old Oct 24, 2006 | 04:57 AM
mt_goat's Avatar
Thanks Gadget! Anyone running temps higher than that?
Old Oct 24, 2006 | 05:34 AM
mastacox's Avatar
I will check mine when I drive to ABQ on Wednesday, that way you'll have a supercharged/aftermarket t-stat reference... sorry about putting it off This will also give me some in-city driving and highway driving to look at.
Old Oct 24, 2006 | 07:06 AM
mt_goat's Avatar
Thanks Brian!
Old Oct 24, 2006 | 08:48 AM
MTL_4runner's Avatar
Gadget is pretty much right on target.....also depends what time of year we are talking about but in general about 10 F degrees above the thermostat rating is usually a good rule of thumb. I'll try and hook up my OBD for you and see what I get.
Old Oct 24, 2006 | 09:43 AM
Tragic Drive's Avatar
This one time in band camp .....
I was on my way to pick up my new shocks . The ambient temp was over 95 degrees and I was in boost for about a mile or two I watched my temp's go a little over 200 degrees. This observation was made using my OBD2 reader.
Stock cooling fan, Napa 170 thermostat , and 2 stage cooler plugs and no ping.
Old Oct 24, 2006 | 11:29 AM
mt_goat's Avatar
Thanks Jamie and Thomas!
the1998sr5
15
Jul 14, 2020 08:35 PM
TACOJO
Nov 27, 2015 05:26 PM
rjtrials
Aug 6, 2015 07:25 PM
Poncho0206
Jul 10, 2015 06:21 PM
