285's on my 98 3.4L 6cyl 4wd w/ 2.5 lift???
Old Oct 13, 2006 | 10:22 AM
kennyracer77's Avatar
I need some help figurin out tires...you guys seem to be the pros! I just picked up a 98 v6 3.4 SR5 4wd manual runner so I put Donahue racing coils(sick) and bilsteins in back...Can I run 285 75 16 s on my stock rims?????? Thanks for help
Old Oct 13, 2006 | 11:00 AM
RobT2k's Avatar
Yes.
Old Oct 13, 2006 | 12:30 PM
Elton's Avatar
Welcome to YotaTech..... yep sure can
Old Oct 13, 2006 | 02:23 PM
ecchamberlin's Avatar
Yes but you may have some rubbing on the upper a arms. Some do and some don't. Seems to be no ryme or reason to it if you will or not.
Nice choice on the Donahoes. I had a set on my Taco and went cheap on the RUnner with Sway-a-ways and have been kicking myself since. Absolutely the best coil overs sold!
Old Oct 13, 2006 | 02:58 PM
seanz0rz's Avatar
Guest
yea hopefully the bfg AT's dont rub when i lift mine.
this seems to be the tire to run with that size lift unless you have a body lift.
Old Oct 16, 2006 | 01:34 PM
4runnin2's Avatar
I have that exact same setup you have. They fit but there is only like a 1/4" between the balljoint and arm and the tire. Also, if you come up over a hill fast when the truck comes back down you will have contact on the tire and arm. I had to buy new rims, In my mind for safety sake.
I ended up getting new rims and Chaos upper arms.....Bryan
Big Little Bear
230
Nov 13, 2023 11:42 AM
Swim
9
Jan 4, 2016 10:47 AM
Cycles
Sep 29, 2015 06:37 AM
genuinegemini
Aug 3, 2015 04:56 PM
makemusic116
Aug 2, 2015 04:40 AM
