- Can I just swap a 2003 3RZ into my 1998 3RZ?
- 3rd Gen Roof racks
- WHat size nut serts to use with extended roof rack?
- Where to purchase New Dynamic Tensioner
- New Tires!
- Buying lift kit - toytec coilover question?
- Strawberry Milkshake - Trans Cooler Fail
- No heat
- A340F Trans Replace - Cal vs Fed Emissions
- toytec coilovers
- Its finally mine
- Body mount on 2001 4Runner
- Oil Leak 02 Auto 3.4L
- Bandit Runner's Grille Mod
- Strange Issue - Need advise
- Body Lift and Heater core lines Problems?
- Oil In Airbox
- what caues no adance in timing??
- Hazy headlight problem solved
- P1780 issue
- steering "clunk"!?
- MAF Cleaning tip..?
- tranny huh?
- Clutch pedal and spring wear....how does yours look?
- Driveshaft center bearing
- I need a pinout for the 3.4 ecu 1996 4runner
- find a mechanic or use the dealer?
- Post engine swap troubles
- New to me Tacoma, poser pics.
- 97 2.7L Toyota 4Runner Oddly Overheating Please Help
- Trail Gear: Tools and Spares
- CV Boot Modification
- axles wont come out
- Tacoma springs on a 4Runner
- Busted Headlight
- question on brakes
- new headlight bulbs?
- Oil In Intake Box
- A/C Compressor Test Question
- Anybody from Mass know of good Alignment tech?
- CV Boot?
- 1998 4runner with engine knock
- Engine cold and stumbles/misses on acceleration?
- Finally ordered my OME lift kit
- Steering Rack Replacement Question
- 01 4Runner transmission worries
- New Exhaust system installed finally (pic very heavy)
- Front brakes locking up
- Interior Light Bulbs
- hydraulic brake booster and MC question
- Why Do People Use LEDs in their gauges?
- A little change of color
- 99 4runner clock doesn't work.
- 4WD "Light" not working
- 99 Limited Tranny Swap
- Photoshop beadlocks for me
- Is this worn-out tranny/engine mount issue?
- 1999 4-Runner / Bucking Bronc.
- Wheel Bearing, I think, horrible screaching noise...
- *** (up/Down)grading to 4th Gen. Will I miss my 3rd Gen? ***
- Got some questions
- 4runner bilteins shocks tips needed
- Whats it worth?????? 97 4runner
- SC oil change ?
- 34's on fj rims
- Help! Shift solenoid just ain't right...
- 1998 tacoma headlights not turning off??
- Timing belt issue 1997 4runner
- driver side mirror
- Starter won't turn on 3rd gen...
- drive by wire....what to look for??
- LED Climate/Temperature Display
- 98 limited gear ratio
- For those deciding on which shocks.
- Major sway issues after lifting 99 Prerunner
- more lights
- Hard time Starting Tacoma
- will a 98 tacoma 4cyl work in a...
- New tires purchased...
- Headlight Bulbs
- How to disarm Factory Alarm for Remote Starter
- 95.5 rear leaf spring replacement?
- 98 taco supercharged 3rz
- Keyless entry problem, reset ECU?
- new to me 99 tacoma
- PC interface type OBDII and CAN Code scanner in ebay...
- videos after 5.29 install
- 3.4 supercharged 4runner question
- Helo and American Racing wheel pic request
- How do you do this to a 4Runner?!?
- Warn Powerplant HD on 3rd Gen 4Runner
- Air Intakes
- Hesitation on Acceleration
- LACKING POWER.. What do i do??
- RR DIFF LOCK --- Will Not Engage... Help!
- Valet Key
- A340F Replaced, but good?
- Finishing up 5.39=4wd vacuum lines?
- p0304 code ugh!!!
- Brand New Tokico Shocks Blown...2wd strut question
- Panzer's 4runner Pictures (Comments/Questions are welcome)
- HELP...PLEASE speedometer sensor
- Multimode 4wd Vs. E-Locker
- '98 4Runner Headlights always on
- Intermittant buzzing underhood
- How can you free up a sticky tranfer case actuator?
- Why not PAY DOUBLE just for the "Moog" brand box..? tie-rod ends
- Do you know the torque spec on diff bolts??
- Engine Compartment Fuse Box
- Difference between '01 and '04 2.4 engine?
- 892's on a 99 4runner
- New front clip , whats next
- Pics Wanted - Gutted stock front bumper
- OBX Headers
- 99 sr5 4runner transmission problem
- 97 runner trans mount.
- '99 Coils and lift spacers
- 2002 4Runner Keyless Remote issue
- "strange" a/c belt
- 1997 Tacoma - E-Locker
- 99 5vz-fe 4runner sr5 running lean
- reverse has a rubbing noise
- How much for a transmission?
- Front carrier question
- HELP need immediate tips on removal of front 3rd on a 02 4Runner
- Really Really strange starting issues....
- Fuel sender crushed
- spring creek trip....pics
- temperature control problem
- Dorado Gold 4runner and aftermarket bumper pic request
- 96 Toyota 4Runner Shock question.
- electrical gremlin
- Rear hatch lock when opened by key
- Black Box and black out
- 2000 Prerunner 3.4L 2WD Trans Fluid Capacity
- need help with installing a hood scoop!
- New updates to my truck
- My transmission is on the fritz!
- Lightforce 170's installed....
- 15x8's or 15x10's?
- 4runner "grey wire mod"
- whooping noise....wheel bearing or U-joint perhaps?
- Front Shock Top Mount
- Parts
- Trunk lid molding removal
- New Improved ANDY MOD - Real TRAC OFF Switch
- Steering coupler question
- 5VZ Cross Pipe Removal
- Ignition switch problem
- Free Tan Weathertech Cargo Liner for 3rd Gen 4Runner
- any body ever crack-opened up OEM rad, if not, here we go!
- ARB Front Bumper Source for 3Gen 4Runner
- Big 3 mod pictures
- brake pads shim
- Shifting issue-AT
- 99 4runner AT wont downshift
- 99 runner handling questions
- MPG/Performance with 285's and a s/c?
- Check engine light!!!!!!!!
- Using OME 881's with a Rancho strut. Possible?
- need major engine help pleaseeeeee!!!!
- Blew a spark plug right out of the engine
- Just ponied up for an Aussie Locker
- Confused? LC front coils and LC shocks
- sonoran steel 3.0 or.......
- Speedi-Sleeve for Rear Axles..?
- Show me your tailights ! !
- Regearing to 5.29's...Front IFS removal?
- 99 4runner won't start
- E-locker question
- spare tire lock
- E-locker skid
- rear window problem --> don't see how it can be a relay?
- Bad Gas Mileage.??? Getting Worse
- Recommend me an exhaust system
- E-locker inquiry
- getting LC coils to sit level with front end.
- Studs issue
- auto to 5spd swap HELP
- front suspension spacers
- 01 taco 3.4 Catalytic Converter Suggestions.
- Windshield rust repair estimates - (DYAMSS- [don't yell at me, scuba steve])
- using tacoma bilstein trd shocks with LC coils
- Rear Diff armor
- Motor oil overfill
- Front bumper options
- Front axle seal. Need help.
- tacoma suspension
- Disabling DRL on 2001
- OME lift installed
- 3rd Gear takes forever!!
- brakes,rotors,axles
- Anybody running 4.88s w/ 265s?
- Oiling kits for trueflow
- missing body mount bushing ?
- Tire storage
- OME install & steering issue
- What rear diff's work for 98 Runner
- Towing my '98 Taco 2wd Why not?
- 96 4runner new paint
- Cable diff lock / for Elocker
- Rear End Diagnostic
- ABS ring install dimension needed!
- my tire lifts off the ground when turning somewhat fast
- 3rd brake light getting no power? please help me
- 98 4Runner fishtailing problem
- manual tranny gear oil with flakes!
- 3rd set of outer tie rod ends?
- 96 Tacoma - 4wd Dash Light and Buzzer
- Increase Initial timing to Take advantage of New Cams
- 3rd gen rear spoiler?
- Removing Gauge Needles
- 99+ Headlights
- Remote lock unit location?
- Odd problem. Need help.
- 97 4runner 3.4l high idling, hard start
- My DIY 3rd Gen Rear Bumper
- 99+ Center Console
- Tube Bumper Design Begins...
- '04 Tacoma TRD
- 3.4 Wide Open Throttle Problem
- IFS front diff inter-changeability between different years of 3rd gen
- Contractor Roof Rack for 2001 4runner
- making blinker lights into fog lights?
- nail is stuck deep in rear driver side tire
- Installing rear fin/spoiler on 1999 4runner
- Tube bumper front mounting options....
- 98 4runner left clearance light
- Bosch Oxygen Sensors? Bad? Good?
- Throttle Body Cleanout Write-up (w/ PICS)
- 2001 4Runner rear OME installation
- Hi-lift on stock 3rd gen roof rack?
- Fuel lines rusted. Can't get filter off.
- Bad day getting worse
- Do you have a supercharger collecting dust?
- OEM Parts lifespan
- Does better than OEM coolant exist?
- 2001 4Runner Exhaust
- OEM Part Numbers for 1999 4runner TALL (highlander) springs?
- after lifting problem
- Screeching help!
- Gobi Ladder Installed
- Multi-Mode 4WD w/5spd possible?
- 285/75-R16 with stock suspension
- Diagnosis was "Rear End is Trashed".....help me! What to do?
- extra 3RZ WHOOOOO-RA
- Frame Swap/Replacement Experiences
- Another Tundra brake swap
- My truck flying, as promised...
- Left Blinker on Dashboard blinking rapidly
