99 5vz-fe 4runner sr5 running lean
Old Oct 27, 2009 | 08:34 AM
beiruit's Avatar
Unhappy 99 5vz-fe 4runner sr5 running lean
i have a 99 sr5 4runner. I just put a new engine in the vehicle a few weeks ago and i am registering a 02 bank 1 threshold low (lean code). Any thoughts? fyi this problem has been occuring even before i installed the new engine.
Old Oct 27, 2009 | 08:43 AM
Godzilla's Avatar
Post up the code
Old Oct 27, 2009 | 09:05 AM
mt_goat's Avatar
Look to the fuel delivery system for problems. That includes the MAF because it measures the amount of air coming in so the ECU can put in the correct amount of fuel to mix with it. If the MAF info is bad the computer has garbage in, and GIGO.
Also look for vac leaks down stream of the MAF.
arlindsay1992
Jan 23, 2024 01:34 PM
Alaskan91
Sep 21, 2015 04:39 AM
