auto to 5spd swap HELP
Old Oct 21, 2009 | 05:25 PM
awpsome's Avatar
anyone know if there is a write up for a 3.4L 97 4runner? or something like it?
i tried using search cant find anything. and also is 250$ for a 5spd and transfer case a good deal?
thanks everyone.
Old Oct 21, 2009 | 06:40 PM
One_96TR4's Avatar
There's no write-up. for 250 that tranny and x-case it a steal! Your also going to need the master and slave cylinders, pedal assembly, brake pedal if you can get it (cut auto pedal will work but not as desirable.) Possibly the driveshaft. If you can get the flywheel from the tranny seller great.
Old Oct 21, 2009 | 07:37 PM
phildelfino's Avatar
Don't forget the clutch, pressure plate, throw out bearing, flywheel and bolts.
Anything else???
Old Oct 21, 2009 | 07:38 PM
Forgot the crossmember and the driveshafts are supposed to be different between the two.
Old Oct 24, 2009 | 09:51 AM
stir_fry_boy's Avatar
You also need all the interior parts (console around shift levers, shift knobs, boots etc). You also need to find a way to disable the "start only in P or N" function in your truck. Some people just "trick" the computer into thinking it is in N all the time.
Old Oct 24, 2009 | 10:30 AM
TubedYota's Avatar
My friend and I did this to a Geo tracker he had.......it's much easier and cheaper to find a truck that has a stick in it.......it can be done, but all the little things that you don't realize will be a problem start to drive you nuts. Just my 2 cents
Old Oct 24, 2009 | 01:14 PM
awpsome's Avatar
mmm thats what i figured their just is so many factors to do a swap..
my friend mentioned about b&m shifters? anyone know anything about that? or what it is? haha thanks
Old Oct 24, 2009 | 01:46 PM
TubedYota's Avatar
It's just a shifter http://www.bmracing.com/bmracing/default.html
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
deepmarsh
Aug 6, 2015 03:44 AM
Michael oaks
Jul 27, 2015 11:47 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
