OME lift installed
Old Oct 20, 2009 | 09:19 PM
02_Limited's Avatar
OME lift installed
Couple crappy cell pics in front of my buddy's place. 881/906 install on the comfort shocks. I measured about 4" of front lift, and a bit less than 3" in the back. Weird stance but it's growing on me. Should look better once I get 285's on. Once I get my camera working again, I should have my LED tails/clear corners & bumpers/ Hella 500's installed and will post up more pics
Old Oct 20, 2009 | 09:27 PM
whokrz's Avatar
I remember when my old 97 4runner was that clean
Old Oct 20, 2009 | 10:13 PM
Elton's Avatar
holy big pics batman looks real nice
Old Oct 20, 2009 | 10:20 PM
3w41d's Avatar
looks great
Old Oct 21, 2009 | 06:44 PM
^99runner^'s Avatar
nice looking runner man
Old Oct 22, 2009 | 08:43 AM
02_Limited's Avatar
Thanks. Got all my other parts in the mail and installed (sans the 500's) but my camera got dropped after I took like 7 pictures. Here's a couple of em
Definitely need an alignment lol
Old Oct 24, 2009 | 11:25 PM
skjos's Avatar
I have the same lift on my '02, the 881's will settle pretty quickly and you will be level.
I tried 33's after my lift and they did not fit... but I was opposed to doing any trimming and it looked like there would be a lot of it. You may want to consider a 1" body lift, to reduce the amount you need to trim.
Old Oct 25, 2009 | 01:31 AM
02_Limited's Avatar
Thanks for the compliments. yeah I'm a little skeptical about them fittin in the rear, but I'll either be going for 265/75/17's if I find the rims I want or same size on stock rims. 285's, IMO, look a little too meaty on the coke bottle rims
Old Oct 25, 2009 | 09:42 AM
Ron Helmuth's Avatar
looks real good and can you tell us about those front mudflaps?
Many of us rub the factory ones running just 265/75/16s and you seem to have found a solution that will fit 285s.
Not sure but you might have rubbing going up to 265/75/17s. Be sure before you commit.
The diff drop is installed? Your CV angles still seem kind of steep to this untrained eye.
Old Oct 25, 2009 | 09:44 AM
Elton's Avatar
must be all that cladding that rubs i got miles of rub with 285s
Old Oct 25, 2009 | 01:20 PM
skjos's Avatar
I just noticed the toytec sticker on your rig. Did you install the toytec top-out spacer with the 881's? If so that may be the reason for the 4" in front and the steep CV angle. To fix the rake you need to remove the spacer or go with 890 coils in back.
If you go 890's in back, you might also want to get a adjustable pan-hard bar.
Old Oct 25, 2009 | 01:32 PM
JuJew's Avatar
Looking good! Nothing like a new suspension. before my lift I was at about 33 inches from ground top/middle fender and after was at 37 inches in change. I love the new stance!
You're ride is looking clean!
Old Oct 25, 2009 | 02:20 PM
02_Limited's Avatar
Thanks for the compliments guys. Yeah, I do have the top plate spacers installed on the 881's. I kind of like the look (definitely prefer it to being higher in the back, but that's just my personal opinion) of how it sits. I only half assed that CV picture, I'll get some better ones up. To be honest, I don't think they are at an alarming level at all. Just a little steeper than stock. I think it will level out a bit too. Here's a more recent pic:
Ron, I got the front mud flaps from Advanced Auto Parts (same as Autozone, NAPA, etc) and they were about 9 bucks. Since I removed the running boards I wanted to protect my lower cladding still so I got some cheapo flaps. They look pretty good and are pretty effective.
Old Oct 25, 2009 | 05:09 PM
^99runner^'s Avatar
the 881's with the top out spacer is supposed to give 3" of lift. correct me if i am wrong but the way he measured it is probably from the ground to the middle of the fender. the correct way would be from the center of the wheel to the middle of the fender, that way the amount of pressure in the tires would not be a factor
Old Oct 25, 2009 | 05:41 PM
02_Limited's Avatar
Should have measured before the lift, but unfortunately I didn't. All my tires were at 36 PSI , after every car wash I even out the tire pressures since there's free air available, so I figure they're pretty reliable numbers. At the front I measured 37.5" from ground to top of fender, and for the back I got 36.5". The lift looks so dramatic mostly because I own a "lowrider" year. Also, the bottom of my tow hitch is now at 18.25"
Old Oct 25, 2009 | 07:44 PM
ghtomrk's Avatar
Very clean looking 4runner. I just picked up an '02 SR5 with the limited flares and only 80k miles. Just upgraded from a '96 and figuring out all the 'lil differences.
Old Oct 25, 2009 | 09:02 PM
theferg's Avatar
In that full frontal pic it looks like you hadn't gotten an alignment (for caster and camber)...? If you haven't done it yet, I would suggest you do it pretty quick if you are driving it much. After I lifted mine, I went about 300 miles before I got it aligned and I ended up with some very bad wear on the front tires.
Will also slightly affect how tall your front is standing.
Oh, and looks great! I dig the color too Apparently, in 2001 or so, this gray metallic became the new white for Toyota...
-Ferg-
Old Oct 25, 2009 | 09:15 PM
02_Limited's Avatar
-Ferg-
Yup, still haven't gotten the alignment... I must have put like a good 6-700 miles on the lift since last Monday. My Revo's are shot, so I'm just waiting until I get new tires to get the alignment. Handling is a bit squirrelly (spelling?) though. Plus have had an extremely busy week at school, at work, and preparing for court tomorrow AM...
But thanks for the compliments y'all
Old Oct 25, 2009 | 09:41 PM
Elton's Avatar
yea when i lifted mine the alignment was really really off i only put about 60 miles on it though so i didn't hurt the tires
Road Bull
Oct 10, 2015 04:55 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
