Blew a spark plug right out of the engine
I just paid off my truck a couple of months ago and hit 153k miles and this is my little story.
I was driving along and I heard this popping sound and thought it was another car and then I got on the gas and I heard it again and thougth "WTF?"
My first thought was I'd blown an exhaust gasket since that is what it sounded like and then I slowed down at a light and blue smoke starting coming from the wheel well and under the hood and I was thinking the motor had blown and fortunatly I was only a mile from my mechanic that sponsored my Eclipse (and handled some maintenance on my Toyota) so I pulled into his shop with the engine blowing smoke,popping and missing like crazy.
The only thing that kept me thinking the engine hadn't blown was the fact that the temp guage never moved.
We look under the hood and on the right side it looked bad with oil all over the place but we got a good look with a mirror and saw no oil coming from the block but was actually shooting out of the 2nd spark plug hole from the front so that made me feel a little better and pulled the coil off ands saw one of the oil seals was tore up and the spark plug had blown out but still screwed back in fine so that was a good thing.
The diagnosis was the coil pack apparently got a short and tore up one of the seals thus dripping oil down into the plug well and most likely lubed the plug threads till it vibrated itself loose and then blew out throwing oil all over the place.
It's all fixed now and they also removed the valve cover and checked out things underneath (I was concerned about sludge buildup) and it all looked good so they buttoned it all up with new seals and gaskets and a new coil pack and plug and will be picking it up in a little bit.
So,just a minor glitch and a huge relief after thinking the worst.
I found a really loose plug 2 different times in my 3.4, but never had 1 blow out, I guess I was just lucky I caught it before it unscrewed itself all the way! I wonder if it has to do with the low torque rating (like 165 in. lbs.).
it can happen form a bunch of things, stripped threads from hacks working on your truck, to high of a compression ratio, improper tq of spark plug resulting in ineffective use of crush washer.
not sure on these engines though why that would happen and or be a common thing, a heli-coil is often used to fix this, if the op actually had a plug blow out. this was more like jiggled out ;-)
i've personally seen and dealt with this before on other vehicles just not on the yotas yet!
way to keep a level head and get right to it man! you'd get some idiots who would just keep on trucking for a week!
It seems as though the 98's were the most trouble free IMO. lol
the oil filled the sparkplug well up and the oil seeped down into the threads thus lubing them allowing the plug to vibrate loose hence the plug coming out which is definetly weird..
Yo,
Oil on the threads may have not been your issue at all read on brotha..
I had a finger pressure loose plug on the passenger side (middle cylinder) of my 99' SR5 3.4L engine.
Eventhough I was trying to be careful on the past plug installs..Unfortunatly, I think I was too light on the torque and used too much "anti sieze" for the plug threads. With these plugs it feels like the torque is good because of the crush washers..I thought I torqued it enough yet I wasent sure so I backed out the plug again... when I looked at it, sure enough the "Crush washer" was not even dented.
So, when I originally changed the plugs and the crush washers did not bite the plug hole enough. I discovered this by hearing a strange noise (pinging sound) so I then I proceded to check it out. I needed a plug change out anyway as I was past the 30K interval.
FINGER LOOSE... scary AND I saw discoloration on the valve cover from the "blow by" past the loose threads. No permanent damage however.. 170K... & Thank goodness. I think the crush washers for the new plugs made it feel like it was torqued enough...I feel now that an added & CAREFUL 1/4 to 1/2 turn is ok for the plugs because of these crush washers, I also only use a small drop of "anti sieze" for the plug threads... Again my bad.
Yo,
Sorry for the threadjack. Now back to your regularly scheduled program.
Yeah, the dealership did a free recall on the rear coil springs and the head gaskets on my '97 back when I first bought it in '01. They told me the head gaskets needed to be done because my VIN# was within a batch of 4runners that (some of them) got their HGs installed upside down from the factory.
