PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. LC80 Springs??
  2. hastings air filter
  3. Magnaflow Recommended 2" Pipe for NA 3.4L - OPINIONS??
  4. Plastic removal tips?
  5. Fixed Transfer case leak
  6. Seat Covers
  7. Fog Light Install
  8. best way to put on hella fog lamps on tacoma
  9. Guaging Interest: Jardine Catback For 99-02 4Runner
  10. thump noise on take off
  11. Accessory compatibility between Gen 2 and Gen 3 runners
  12. Totally Customized 02 4Runner on 20"s, 5% Tint, & More!
  13. Removing Supercharger. Questions..
  14. will 16x9.75 rock crawlers w/ 4.5 BS fit fine?
  15. Will these work?
  16. Will Sony Playstation Drain the Battery ?
  17. Shock choices?
  18. Rear Diff Protection?
  19. finally installing lift on 4runner need wheel tire advice
  20. burn hole patches??
  21. K&N intake system
  22. Question for those of you who replaced you running boards with sliders...
  23. Where can i get a set of the 00-02 4runner rims
  24. Quick Amsoil Question ????
  25. Black or polished chrome wheels for my rig?
  26. did the seafoam treatement
  27. Holes in headlight lens
  28. door lock problems
  29. lights seem to be a little dull
  30. Help a noob. Looking for skid plate options for 97 4Runner
  31. turbo manifold for the 3.4?
  32. 2001 Tacoma front diff. leaking bad out vent?
  33. Spacer lift
  34. tire question for 2002 extra cab tacoma 4x4
  35. 3rd Gen 4runner tube front bumper
  36. Another 2.7L longevity thread
  37. Idle surging
  38. question about my new 4runner
  39. little video i had on my comp..
  40. Temporary alternative to AMS Oil
  41. changes in Rear 4runner hatches
  42. 01 3.4 engine
  43. tacoma roof rack
  44. 02 4Runner Tail Light Guards
  45. Need front bumper
  46. Double Cab Owners Show Your Stuff!
  47. Polishing Base/Clear
  48. Sonoran Steel Lift System # 7 Installed - Lots o' pics!
  49. E-Locker?
  50. 02 4Runner Map Lights?
  51. 2002 Toyota Tacoma Xtra Cab V6 Manual TRD won't start (54k Miles)
  52. Bilstein Shocks for '98 TRD
  53. Help! Dealer Swiped My Filter Remover!
  54. before and after painted wheels
  55. Unused Borla Muffler For Sale
  56. 1999 4runner remote add on Rs3000
  57. Airbag warning light
  58. Towing in overdrive with a 2000 Limited?
  59. pp springs worth it for a 99?
  60. Axle seal installation question
  61. Shop Recommendations? (DC/MD area)
  62. Found a good deal on tires- can I fit them
  63. deckplate mod questiion
  64. Road Rage(pics)
  65. 98' Gauge Cluster in a 97'
  66. Flowmaster 50series SUV PERF
  67. Just got my 4runner
  68. Magnaflow XL Turbo Series Reversible???
  69. Garmin 276c GPS Mounting
  70. did 96 4runners come in tan and oak? or does tan=oak?
  71. Strange Gas mileage results with deckplate
  72. Functional RAM air idea...
  73. Simple Push Bars
  74. question on 2002 3.4 tacoma
  75. noisy 5 speed?
  76. Axel wrap????
  77. installing spark plugs on 2002 3.4 v6 tacoma
  78. CBI hitch tire carrier, thoughts?
  79. CB Install: yea or nay?
  80. 02 4Runner Gauge Bulbs??
  81. Anyone in Edison NJ area??
  82. Buying a Tacoma
  83. Boosted + Fueled... Tuning scheduled for Monday on dyno
  84. 3rd Gen 4 Runner Lock Right Install Writeup?
  85. shaking
  86. Brakes...
  87. Dual Exhaust on 2002 4Runner?
  88. Bumper compatibility?
  89. Removing transmission pan....2 quick questions
  90. green and red coolant
  91. alternator question
  92. oem Elocker master install kit vs V6/turbo
  93. Ideas for Cupholder..
  94. 1997 limited or 1998 SR5 - buying help
  95. fuel filter- 2002 3.4 v6 tacoma 4x4
  96. 99 4x4 Limited 4Runner - Tranny issues @ 94K?
  97. 2WD Locker
  98. LC coils
  99. WTB Driver's seat '00 Limited Runner
  100. Springs?
  101. Need New H.O. Alt. Suggestions
  102. Anyone have a light bar on their taco?
  103. 4Runner + F250 = bad things
  104. How many miles on your 2.7L?
  105. thought you guys might want to see this
  106. Mounting Driving lights in the front bumper?
  107. "D" gear select light
  108. What maintenance items would you do @ 200k?
  109. Any ideas on what this is?
  110. 3rd gen auto transmission rebuild cost???
  111. iridium plugs and regular plugs for 2002 3.4 liter
  112. Is this noise normal?
  113. Fuel additives?
  114. Spark Plug Wire ?'s
  115. HID retro #2 in Tacoma using Acura TL's lots of PICS
  116. A new owner of an 'old' 4runner...
  117. More Gap
  118. Thump when hubs locked
  119. CHEAP Beckson 4'' Deckplate
  120. New truck, and a couple of questions
  121. 97 4Runner 3.4L muffler question
  122. Tacoma Parking brake in 4Runner
  123. Here is a new pic since the wreck!
  124. What year LC wheels require special lug nuts?
  125. Larger Sized Magnaflow Opinions
  126. H4 Halogen Bulbs - Anyone using these with stock wiring?
  127. How can I tell if my 4runner has a suspension or a body lift.
  128. Rear Door Hydraulics
  129. Clutch soon to die what are the good ones?
  130. 3.4 + 33s + 5spd = what gears?
  131. Anyone use Denso oil filters?
  132. Failed Smog Check
  133. Powdercoat or Paint Rims?
  134. Where is the tail light relay...?
  135. Where to buy OME Kit
  136. Mud Flap Mod?
  137. What is a fair price to ask for my '97?
  138. 4Runner Brake issue
  139. sounds like valves
  140. What color is my 4Runner?
  141. a few pics
  142. 1998 Driveline problems
  143. Top Plates
  144. Photoshop help please!
  145. Accurate ambient temp gauge.....a simple test
  146. TRD Headers, does anyone here have them?
  147. Exhaust
  148. Suspension lift
  149. 5 Speed Swap?
  150. 1997 limited high miles???? should i get it
  151. brake pedal feels wierd
  152. Show me your lift! I wanna see the difference in lifts 1.5",2",3"4"
  153. P/S pump...rebuild or replace?
  154. Purchasing a new lift. Need opinions
  155. Questions about 2001's
  156. YouTube Video: Jardine Exhaust System on my SC'd 4Runner
  157. newbie here 22re ?'s
  158. lift
  159. 99 4runner limited climate control problem
  160. wobbilly rear tire
  161. arb bumper mods
  162. Some filthy winter driveway pics....
  163. Newbee Needs Advice and Criticism
  164. OME 890 vs. 891?
  165. HELP! I can't get into my truck!
  166. E-locker Broken?
  167. Adding Gauges
  168. 4wheel drive acting funny
  169. Clean engine
  170. what is a diff drop?
  171. oil under my air filter?
  172. Rear Wind Deflector
  173. New to Yotatech. Purchasing a 4Runner..Question ?
  174. wiring offroad lights on surco rack
  175. tough decision
  176. My new Tacoma (pics)
  177. Overall Height....with and without lift/bigger tires
  178. Clicking Sound after new CV install
  179. 99 4runner slow to get going in the AM
  180. Pictures of 3rd gen 4Runner on 36"-38" tires?
  181. 98 Rear Deflector
  182. Help with engine mounts!!!
  183. Picked up fzj80 wheels today!
  184. keyless entry
  185. need help fast Biggest tire on 97 v6 4x4 4runner...i searched
  186. Difference in TRD Leaves?
  187. Introduction (pics!)
  188. When was yours born? build date
  189. tokico front shock question - (PIC)
  190. ECT mod or 170 degree thermostat?
  191. Loadwarrior vs. Megawarrior
  192. LC Engineering street heads
  193. Rear oil seal replacement?
  194. Better ride with no fr swaybar
  195. power increase with a supercharger?
  196. toytec ome3 question
  197. Why does my V6 4R sometimes hesitate & stalls when accelerating from stop?
  198. Opinions on 4runner vs LC
  199. CEL code 1153
  200. 3rd gen runner turn signal lights loose.
  201. Old Man Emu lift for a 2000 4Runner, some questions..
  202. Rear Door Won't Unlock
  203. clutch pedal vibration
  204. Longevity Poll: Mileage of a 3.4L
  205. Can someone confirm: 96-98 4Runners Had Longer Stock Bumpstops
  206. Jardine Catback Installed
  207. Toyota e-locker gear ratio
  208. Tailgate Latch Return
  209. Heated Seats Pre-Wired?
  210. Fuel Richening Question
  211. 98 Tacoma Cylinder 5 Misfire
  212. Transmission pressure flush a bad idea??
  213. trekmaster discontinued?
  214. Best universal joints
  215. Camber Adjustment after System 7
  216. My Tundra OME buildup thread w/pics
  217. Rear axle inner seal part # question.
  218. Doing the Clutch this Weekend
  219. Feeler - Hella 4000 lamps (2)
  220. Need real time help please
  221. 99 4Runner Automatic climate control heater issue
  222. Tire choices.
  223. Factory Diesel conversions for Toyota's in the US
  224. Is this a problem with my transmission shift solenoid?
  225. Tired/ungly leather seats..anyone get replacement covers ?
  226. A simple onboard device....How does it work??
  227. 3rd member swap
  228. 7th + URD AIC Kit
  229. Vibration at high speed/diff angle
  230. Rear shocks won't budge!
  231. Wierd brake and electrical problem???
  232. Tundra/Sequoia Wheel Assistance for My 4Runner...
  233. General Maintenance Checklist
  234. Stalled during heavy accelleration
  235. new member....
  236. 2002 4Runner - Ignition or Replace Battery?
  237. How to check gear ratio of front DIFF?
  238. SOS Fuel filter help ?
  239. Price my '99-Should I or Sell or not?
  240. Normal water temperature
  241. ELocker Problems
  242. Custom Side-Exit Exhaust (Chopped Pics Inside) - Opinions Needed
  243. front IFS ARB locker number for a 3rd gen
  244. TJM installed - 4RUNNER GONE :( pics
  245. Transmission pan bolt torque spec ?
  246. No reverse lights.....fuse? switch?
  247. Hello! All!
  248. Schematics Needed
  249. New Wheels?
  250. 1 Automatic Door Lock dies
