Toyota e-locker gear ratio
Old Jan 30, 2007 | 09:08 AM
KZN185W's Avatar
Is the Toyota e-locker independent of the gear ratio? What I mean is can an e-locker be transferred to another diff that has a different gear ratio without causing any problem relating to the differing gear ratios?
Or do I need to change also the gear ratio?
Thanks!
Old Jan 30, 2007 | 10:26 AM
mt_goat's Avatar
The e-locker should be compatable with other gear ratios, maybe not all of them, but I'll go out on a limb and say most of them. The bigger issue with it is the diff housing is different and takes some fairly major modification to fit into a non-elocker axle. Unless you're pretty handy with metal fabrication, most guys swap the whole axle (drum to drum).
Old Jan 30, 2007 | 10:39 AM
d0ubledown's Avatar
you can swap whatever ratio you want on the elocker (with exception of the factory 4.88's i think). yes, if the ratio that the elocked 3rd is going on doesnt match whatevers on the third, it has to be regeared. id be willing to bet most elocked 3rds are 4.30 & 4.10. as mt goat stated, the stock axle housing has to be modified.
Old Jan 30, 2007 | 11:06 AM
Elton's Avatar
i think i have 4:30s
Old Jan 30, 2007 | 02:13 PM
mt_goat's Avatar
Here's some info on modifing the axle housing:
http://www.4x4wire.com/toyota/tech/electric_locker/
Old Sep 14, 2010 | 08:09 PM
808nickh's Avatar
i have a quick ? i have an 85 runner and i wanna put elockers front and back i have them already but both with different ring and pinion sizes one of them has a 41 tooth ring and 11 tooth pinion the second has a 43 tooth ring and a 10 tooth pinion i dont have the vin number of the vehicle it came off of and dont know what the ratios are? i wanna throw one in the back and just run the rear elocker tell i do my lift but i currently am running 4:10 also does the pinion flange bolt str8 up to the driveline or does that require modification?? guess that wasnt such a quick ?
vasinvictor
Jan 20, 2016 12:39 PM
YotaLogic
12
Nov 17, 2015 06:27 AM
merc1100sc
Jun 26, 2015 05:24 PM
ACZR
Jun 23, 2015 07:55 PM
94hiluxZE
Jun 22, 2015 10:42 AM
