oil under my air filter?
I noticed that I Have oil under my air filter. any ideas what the problem coudl be? I have never seen this before.
I appreciate the help
Patrick.
Patrick.
wow Im sorry I dont have any help but the same thign happened on my quad. I could never figure out the reason.
From that first pic, it looks like its coming down the tube that is aft of the filter. Is it?
I had the same problem with my old 4Runner, the whole intake was full of oil. Sorry to say that I don't know what caused it either. There might be a few vacum lines that connect to the valve covers, in this case that would probably be where the oil is coming from, but I don't know.
x2 on the pcv takes all of 5secs to replace it but i would get some intake cleaner and clean the tube real good and the throttle body and then clean the maf with ether electrical contact cleaner or maf cleaner
thanks guys. I'm going to my dad's this weekend and i'll get it swapped out. Hopefully that's all it is. I'll keep you guys posted.
Thanks again .
Thanks again .
If you change the PCV valve... get a new grommet (sp?) as well... The rubber hole the PCV valve plugs into... I just got a new one and when I removed the old grommet, the crap just cracked into three pieces...
well guys we took a look at it today. Can't you check to see if a pcv vavle is good by blowing on it and one side should let air out and the other should not? the old pcv valve did that, but the one that we replaced with allowed air both ways? anyways. the tube leading to the intake was lined with oil and the little "reservoir" was full of oil. I am not sure how long it took for it to fill. We did a dry compression check and all cylinders were ~160. it seemed a bit low, but at least they were all pretty much the same. We also noticed that the oil seemed to be close to a quart over.
maybe from here?
I appreciate any ideas you may have.
Thanks again.
maybe from here?
Thanks again.
