Clicking Sound after new CV install
Old Feb 1, 2007 | 06:17 PM
CLEANSR5's Avatar
Quick question. I broke my cv half shaft in hollister this past weekend. I got pretty nervous with the clicking so I took it to the gilroy stealership to get it repaired. Every since I got it back, when I slow down to a stop there is this strong click, it clicks then 5 seconds later it clicks again. Sounds something like a bent rim, just to give an example. Not sure where to start, but it may be linked to the CV install, I don't know. Just curious, has anyone else had this noise after a CV repair job? Thanks in advance.
Old Feb 1, 2007 | 06:23 PM
DeathCougar's Avatar
I would be checking your diff. If you broke an axle, you may have done damage to your diff too.
Old Feb 1, 2007 | 06:25 PM
IE perhaps a broken tooth.
I did have this problem in my 86 4Runner, and it turned out to be a missing brake spring (the ones that hold the pads and keep them from moving around in the caliper). Look at that too, make sure those brake pad spring clips are there.
Old Feb 1, 2007 | 06:30 PM
CLEANSR5's Avatar
Ok, thanks, I guess im gonna have to return to Toyota for a quick diagnosis of my e-locker problem, thanks, I'll mention it to the tech.
Old Feb 3, 2007 | 09:36 AM
CLEANSR5's Avatar
Called a few dealerships this morning, they said that the clicking sound was normal in some Tundras, 4Runners and Tacomas. Strange...
Old Feb 3, 2007 | 09:48 AM
NORMAL? i dont think so!
Old Feb 3, 2007 | 01:55 PM
Mason Dixon's Avatar
could be a crappy axle they put in too, make sure its OEM
Old Feb 4, 2007 | 08:34 AM
CLEANSR5's Avatar
interesting, I do remember the tech saying that the only way they could have my truck done in 1 day was to order an aftermarket half shaft...i think it's time i call this guy and see what exactly he installed.
clok
Aug 1, 2015 09:42 PM
94yotaky
Jul 23, 2015 07:50 AM
Sandman
Jul 14, 2015 12:36 PM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
