tokico front shock question - (PIC)
Old Feb 1, 2007 | 07:30 AM
Mojo_Risin's Avatar
I'm going to be removing my SAW's and going back to a coil/shock set-up but I tossed my old hardware (ie. the OEM top plate). I have a line on some new(used) topplates but I'm wondering if i need to get any additional parts or if the Tokicos come with the parts shown on the red below - like the rubber cushions and retainers (not the top plate - i know that's separate)
thanks
John
Old Feb 1, 2007 | 07:34 AM
Localmotion's Avatar
You should get new bushings and retainers. As far as top plate, nope. There is also a rubber gasket type thinger that goes under the top plate.
If you are running the tundra set up, dont forget to order extended studs and the 3/8" spacer.
Old Feb 1, 2007 | 07:46 AM
Mojo_Risin's Avatar
Are you saying I should get them with the shocks? or are you saying I should get them - meaning i should buy them from someplace?
Sorry - it's a little confusing.
John
Old Feb 1, 2007 | 07:48 AM
John
oh sorry man.
You should receive the bushings, retainers and nut with the shocks....at least thats what I got with me OME set up. It may differ now that I think about it. Call them and ask.
Old Feb 1, 2007 | 07:51 AM
TRDatVT's Avatar
You can get the top plates at advance (strut top mount) for 50 a piece new. Do you think i will need the piece for under the top mount also, or do you think it will come together?
Old Feb 1, 2007 | 07:58 AM
UNR.Grad's Avatar
Yes you need the cushion to seat the coil properly to the top plate. It should come with the top plates; with OEM parts they are sold together, top plate and cushion. But used is a way better way to go, you can save a ton.
Old Feb 1, 2007 | 09:32 AM
seanz0rz's Avatar
Guest
oh sorry man.
when i got mine, all i recieved in my shock box was a shock with a nut on the top. in the rest of steve's packaging i had teh bushings for the eye, but that was it.
im still trying to track down the new bushings for the top...
anyone know where they sell those? model numbers, etc.
Old Feb 1, 2007 | 10:11 AM
gpcollen1's Avatar
Dealer for the bushings...
Old Feb 1, 2007 | 10:24 AM
seanz0rz's Avatar
Guest
ohh, how much does the stealer want for the bushings?
and do i buy them for a 4runner or a tundra? they are tundra shocks
Old Feb 1, 2007 | 01:27 PM
toyotaoffroad91's Avatar
tokico's do not come with bushings only a top nut..you can get them from a dealer or go poly and get a universal set from energy suspension
Old Feb 1, 2007 | 01:32 PM
Mojo_Risin's Avatar
Get them from a Tokico dealer or a Toyota dealer - or is that basically one in the same?
john
Old Feb 1, 2007 | 02:13 PM
seanz0rz's Avatar
Guest
and where can i source a universal set from energy? and how much am i going to pay for my 4 bushings if i get that universal set?
Old Feb 1, 2007 | 02:22 PM
mtnwheeling's Avatar
Any auto parts store worth a ^%$ shoud have them. They should run about 5 bucks or so. I will try and find the part # I used for mine and let you know.
Old Feb 1, 2007 | 04:32 PM
Mojo_Risin's Avatar
yeah, finding the bushings isn't proving to be the hard part - finding the "retainers" is a different story.
heres energy suspension page... http://www.energysuspension.com/pages/toyt1.html
Old Feb 1, 2007 | 05:16 PM
BajaRunner's Avatar
Sway a Ways.. :)
You selling them? How much?
Old Jul 21, 2007 | 06:28 AM
KZN185W's Avatar
The Tacoma TRD Tokicos I recently bought came with 2 bushings per strut only. no nuts and no retainers.
Can i use the ones for the OME N91S? have not checked if the nut will fit.
Also, should i use the bushings that came with the Tokicos?
Thanks.
Old Jul 21, 2007 | 06:53 PM
frodin1's Avatar
The rear LC OEM shocks are the same way. Problem is most people toss the retainers when they get aftermarket stuff. I ended up getting mine off someone very cool for free on ih8tmud. Sonaran steel says they can help out if need front hardware. Have you called Steve?
Old Jul 21, 2007 | 09:45 PM
KZN185W's Avatar
I didn't get the shocks from Steve plus i live in the Philippines so it would be too much to ask for his help in this case. I'm planning to order the nuts from the Toyota dealer here.
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:34 PM
toyoda8488
Jul 5, 2015 10:18 PM
