Help! Dealer Swiped My Filter Remover!
Old Feb 10, 2007 | 06:45 PM
Pipsisiwah's Avatar
Need Oil Filter Remover That FITS!
Where can I get a cap-style tool that fits a 1998 V6 Toyota factory oil filter? I looked in Checker, AutoMart, AutoZone, Napa, CarQuest, K-Mart (where I bought one 9 years ago that fit, but somebody boosted it a few months ago), WalMart, and several other smaller or independent stores. No gots.
Last edited by Pipsisiwah; Feb 10, 2007 at 06:59 PM. Reason: Poor title, message too long
Old Feb 10, 2007 | 06:51 PM
CJM's Avatar
CJM
Not much you can do, try online maybe. I have a claw style one myself.
Old Feb 10, 2007 | 06:53 PM
Elton's Avatar
ahh one reason i like to do the work my self ive never used a filter wrench my self and its never leaked
Old Feb 10, 2007 | 07:01 PM
habanero's Avatar
I got one from the dealership, don't remember the brand....checked for fit by borrowing one of their filters.
Lisle and KD worked well for me too, but you've prolly tried those.
Ok, just checked what I have now... a Vector 17075, nice solid fit on the oem filter
Old Feb 10, 2007 | 07:02 PM
Pipsisiwah's Avatar
Hmmm. I usually remove the front wheel and access it from there. I have a tool that fits over the top of the filter and as you turn the tool CCW it contracts and grips the filter, but it's no good for tightening the filter.
I hope hand tight is tight enough... but I'm staying in town until I can get another 1/3-1/2 turn on the thing.
habanero's Avatar
Oooh muscley! I sure wish I could do that.
Old Feb 10, 2007 | 07:04 PM
saulgoode's Avatar
Totally agree, on a V6 there is plenty of room to access the oil filter from the driver wheel and get enough leverage to loosen and tighten it by hand.
Pipsisiwah's Avatar
Hi Habanero,
Do you remember where you bought your filter remover tool? and is "Vector" the brand name of it?
CJM's Avatar
CJM
I can do it, but when your covered in oil its tough to grip the thing..
Old Feb 10, 2007 | 07:07 PM
Elton's Avatar
will im useing a bigger fliter than the factory so theres not much room left and its not easy for me to get my fat arms up there to change it
Old Feb 10, 2007 | 07:08 PM
kevin444's Avatar
i do the same my armpits is rested on the driverside tire and im yeah loosening it off
Pipsisiwah's Avatar
Yeah, but when one gets old and feeble and it's freezing in the garage, one tends to look for an alternative.
Old Feb 10, 2007 | 07:10 PM
habanero's Avatar
Originally Posted by Pipsisiwah
Hi Habanero,
Jay Wolfe in St. Louis, MO. Got it in hand and yeah, stamped inside is
Vector
Part No. 17075
made in the USA
Old Feb 10, 2007 | 07:15 PM
Pipsisiwah's Avatar
Vector
Part No. 17075
made in the USA
Oops. That's a long ride from Grand Junction. Time to go surfin'! Thanks for the info.
And to the other replies, thanks also!
Old Feb 10, 2007 | 07:16 PM
habanero's Avatar
Are you guys kidding? I had to get married to have an in house cap unscrewer. Very convenient.
Then again, with my long skinnies I can reach right in and get to it, and I use a converted veggie oil bottle to funnel it beyond the skid plate so no removal of wheel or skid.
Old Feb 10, 2007 | 08:03 PM
rynosurf's Avatar
check this out.
http://www.tacomaterritory.com/forum...ght=oil+wrench
Old Feb 11, 2007 | 04:03 AM
gpcollen1's Avatar
I think many of us just use our hands! How tight do you put that thing on??
Old Feb 11, 2007 | 04:49 AM
habanero's Avatar
Not tight enough to squeeze the gasket out, just tight enough it can be easily taken off with a wrench (in my case) or by hand (in the hubby's).
Old Feb 11, 2007 | 04:53 AM
20005spd's Avatar
you dont need to tighten an oil filter with a wrench. in fact you will ruin it if you do. read the filters 99% of them will tell u
#1. put a small amount of oil on the filter gasket
#2 once the filter touches the block only about a half turn or so.
basically till its snug, not @ 50ftlbs and crushed to ?…?…?…?… cuz you tightened it with a wrench.
i work @ nissan their filters as well as toyotas are small. i use an $8 wrench from auto zone. it has 2 sides that are connected by cheap spring it grabs it off & your done.
in theory you should never need a wrench if you tighten the filter correctly and change it often.
Old Feb 11, 2007 | 05:13 AM
Rivalred's Avatar
Originally Posted by rynosurf
I used a similar one lke that when I use to do oil changes in high school. They work great....
