- Exhaust
- Need info on Turbo installation
- Any Western PA lift installers
- Used Goodyear MT/Rs
- NC 4Roc members, I need some help
- Bumper Warp
- taillights, corner lights, gauge lights are out - not fuse
- It's Amazing How Well Your Car Runs Without Rocks in the Exhaust
- Taco spring swap
- Helper Spring install ?'s...
- Moster 1st gen in Keller???
- ??Starting a brand new motor for the 1st time??
- happyness but need help!!!
- Tacoma Lights Question
- Grille Guard/Lights Question
- Need shocks for 3rd Gen 4Runner
- exhaust is in the way
- Bobbed my bed
- good mods for the 2.7 liter
- 3rd Gen 4Runner key.. do they have a chip?
- stock headers, 2.5" cat ->muffler ->2.25" muffler back?
- Cost efficiant cooling help?
- New Paint for my 4runner?
- Rear sway bar bolts
- How long does it take to remove / install Valve Body?
- Cool Bike Rack?
- Question about an 87 Corolla ignition timing
- how's this truck look to you guys?
- Tire question?
- Rear flex shots
- Started my truck today...
- TMC install in a 2000 S/C 4Runner
- Weekend of fun
- Pic request - Grey 4-Runner
- My "new" 4runner
- Buick v-6 swap?
- which rotors/brake setup
- 3rd Gen Rear Latch
- OMG please help
- SoCal lift installers needed
- Window switch and roof rack questions.
- newbie, 92 4runner good?
- engine temperature gauge seems to not be working
- Code Help!
- The incredible rear window switch mod *pics*
- Tire choices
- pic's of dent in side panel
- Is a wider Rear axle worth it?
- kill switch info needed, rig almost got stolen today!!!!!!
- bumper sag, power antenna
- just bought a 4x4, have some questions
- Can I get this fender flare piece? (pic inside)
- Marlin rear brake line
- Lifting my runner?
- Tinting laws question
- Are these spacers any good?
- Parts interchange question.
- Timing belt, all drive belts, & water pump
- HID projector retro in a 3rd gen.
- E-Brake Cable Question
- Wiring question..
- age old question: K&N or Amsoil Air filter?
- cab visor for 2nd gen?
- When does gas light turn on in 3rd Gen?
- caliper differences between '03 and '00?
- The big black uglies (rims)
- 2000 4runner inside length
- Can you import a truck from canada?
- Questions about Wet Okole Seat Covers
- coil springs
- can i dd my vechicle or do i have to regear
- ok u guys need to read this help
- How Much for Aisin Manual Hubs?
- 2nd Gen 4Runner Question
- Potato Salad Toy Rollover clip. This had to hurt.
- what to look for?
- need a toyota
- 99 4 runner inner fender removal
- diesel in 85, 0r 86-89 4runner?
- Critique aux fuse box setup
- Hauling with a Tacoma
- 81' Trekker For sale...
- rear links.... axle placement
- 01-02 4runner climmate control compatible with 99-00?
- Wll this brush guard fit my '91 4Runner
- 4Runner towing..
- Amsoil problem
- Rodeo Brush Guard Fit a 96 Runner?
- Reading VIN numbers
- How can i get more juice out of my engine?
- Major mods done (pics)
- KYB Shock questions
- How HOT are you??? Tranny temp I mean.....
- 3rd Gen Timing Belt Replacement
- Cool Pic
- Bad hail damage - not good in the hood!
- Center dashboard space
- 1998 4Runner... What wire under the fash is for parking lights?
- Your Opinion of the 4 cyl. engine
- Power Door Lock Problem
- I need help installing gauges
- 4wd light
- 95 runner pics!!
- 4R:3rd Gen: Adding a pulley to the belt system...
- Sold it
- Coolant leak -freeze plugs problem
- Is this a bad thing to do to my truck's computer?
- I need some taking off my OME...
- spedometer calibration?
- Wheel Well Trim or No Trim
- Need tire advice for 3rd Gen 4Runner
- bolt size for pickup front frame rail?
- NWOR 3.0 V6 header stress crack repair
- 1kzte conversion
- 3rd gen. How do i remove my spare..?
- what intake and exaust?
- OME 901's before and after
- How much more will my tires stick out with this setup?
- mpg at different fill levels
- 265s, 285s, cant decide!
- Painted my chrome flares black...pix
- V8 4Runner - Webpage Update
- 4.56 or 4.88 gears for 3.4 auto
- Deckplate mod
- GOt my truck will have pics up shortly.
- 4th Gen steering wheel on 3rd Gen
- need pics
- 85 22re EFI A/C Belt
- Mystery Connection - 2nd Gen 4Runner
- Anyone Re-geared after installing taller tires?
- factory sticker removal
- New Memeber Introduction
- 3rd Gen Ladder Rack
- 84-88 Front valance from Performance products??
- O2 Sensor 22RE - How much does it cost ?
- Yoko's M/T+
- Steering squeel?
- EFI to carb and back again?
- New Top for the 4Runner
- Bilstein HD vs Bilstein 5100
- Canadian Toyota 4x4 Sites ?
- QUICK!! How to remove spare tire??
- I have a couple of questions
- went playing today...
- just bought an 82 pickup regear?
- new catalytic converter
- axle seal help
- magnaflow question
- Trailer with a Taco
- squeaking Upper Control Arm with uniball
- ARB Bull bar question...
- MY 1999 4Runner Profile
- names of a few parts.
- Possible new product?
- Vibration/Grinding after OME coils installed! *I've already searched*
- 3.0 turbo 4runner on ebay
- 22RE's - What are your RPM's at this speed?
- 4 wheel drive whine
- Problem Solved re BJ and Aisin install
- Rock Crawler Series 51 or Series 97???
- 3rd Gen Hella Micro DE splash shields
- GOOF-UP: Hard-Wiring a Power Inverter
- Factory flares removal, damn holes!
- A new cup holder mod (early 3rd gens)
- Can't get my alternator off!
- 96-02 4Runner Headlight Upgrade
- Original speaker wiring
- 2nd gen Tire question...
- TRD Cat Back questions
- for ppl with DRL's...
- DRL's on 1997 4runner
- Painted the motor....PICS!!!!!
- Manual Transmission SUV?
- Steering Question
- Auto Dim side mirrors?
- NE1 have experience with this vendor...
- sweet project truck on ebay
- Fixed that squeaky cluch pedal
- PICTURES of my body lift, but need HELP !!!
- 2000 4Runner brake controller wiring
- what years rear bumpers fit 1988 pickups?
- 33s on 17s
- Anyone parting out 89-95 4x4??
- 02,04 tacoma frame question
- These were delivered today!!
- lookin at a rig, what so you all think
- I need a hood Fiberglass or steel?
- Powder Coating
- where can i find OME's?
- Rest of my 3rd gen pics engine, sounds, inside, outside
- Poor accelleration? Low top speed?
- Theft deterrant fuel valve???
- Buildup of 2nd Gen Runner on MOGs w/ Air Suspension (Pirate4x4)
- 4runner/PF wheels
- Looking at an 84 pickup
- where to buy gears from
- Doors Are for Freakin Pansies...
- Getting rig ready for Tellico - NEED SHOCKS, HELP!!!
- 1st Gen. 4Runner Transmission
- weight difference
- Antenna with strong signal ??
- 2ng Gen 4Runner Moon Roof on Ebay
- 02 4runner 16" wheels, running boards
- Leaking Oil?
- Question - Roof Rack Installation
- Where to beef up and where to lose wheight? ? ? ? ?
- Buying a 4runner and upgrades
- Steering Stabilizer install
- Dual exaust
- would u put a new motor in or part out...
- New 4cyl. Supercharger only $2,750.00
- If you're interested in a white face A/C panel reverse indiglo, check this out...
- Need time chart or data
- Air Lift "Ride Control" These things rock!! he he
- fender flare question. i searched
- S/C and 7th injector install trouble codes HELP!!!
- What size are the stock 3rd gen 4Runner wheels?
- STOLEN RIG!!!!! 4runner
- Removal of snorkel on 4Runner?
- Need a part number
- Cruise Switch
- SCORE!!!! Picked up a 4.3 last night
- 86 4Runner factory repair manual, is it worth it?
- I finally got some pics for u guys
- American Cancer Society: Relay For Life Donations Needed!
- IS THIS 4 ReAL ?
- Goodbye Pickup...Hello 4Runner!!!
- Aftermarket exhaust conundrum
- Request for Pics of CV angles
- Supercharged V8 4Runner article...
- tonneau covers
- 2001 Leather Seat Upgrade.....PLEASE HELP
- lighting gurus need help with burtman industries sills
- My 3rd gen 4runner pic
- 22RE Buildup
- 89-95 hood question...
- Question Regarding Jack/Stand Height
- Where is the ECU on a 2004 Tacoma?
- engine swap question
- Gears???
- Got some wheels and a question...
- Need installation instructions for Downey 3.4L headers
- EATON LSD for 2002 4R
- What is your experience replacing R134 with R12 .
- Bunch a Yotas
- Cargo Nets in the Back (Pics)
- 3.0L Headers
- '99 4runner...fog lights on high beam...any ideas about wiring?
- Tranny Swap questions
