85 22re EFI A/C Belt
Old May 2, 2005 | 06:19 PM
ktmrider37's Avatar
My a/c compressor has been out for a while now. in fact i cant ever remember it working. i was wondering i could remove the belt that goes to the compress without causing any problems. the bearings in the a/c are going out and squeeking very badly so its getting annoying. can i remove the belt???
Old May 2, 2005 | 06:22 PM
4Crawler's Avatar
Yep, pull it off, no problem. Mine has been beltless for many years.
Old May 2, 2005 | 06:26 PM
ktmrider37's Avatar
Thanks much, i didnt think it would hurt anything with it off of there but wanted to check with some other folk. i think im just going to take a razor blade straight to it being i dont need a/c with the topper off the back!!!
Old May 2, 2005 | 06:30 PM
4Crawler's Avatar
Easy to loosen the idler/tensioner pulley and then slip the belt off, although you'll have to do the same to the p/s belt and pulley as well. If the belt is in decent shape, it does happen to be the same size belt as the stock alt/water pump uses, so makes a good spare.
MO transplant
Apr 23, 2023 11:58 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Sandman
Jul 14, 2015 12:36 PM
bryan34w
Jul 6, 2015 05:53 PM
