2000 4Runner brake controller wiring
Old Apr 29, 2005 | 06:28 AM
Question 2000 4Runner brake controller wiring
I'm in the middle of adding a Prodigy trailer brake controller to my 2000 4runner and I've discovered that the brakelight switch has four wires going to it instead of the two that I expected. Doe anyone know which wire I should tap to get the correct signal to the brake controller? I'm looking for a wire that goes positive when the brake pedel is pressed.
Thanks in advance,
Jay
Old Apr 29, 2005 | 07:35 AM
dibble9012's Avatar
I can get that information to you tonight, I know I used that wire when I did my remote start, just cant remember at the moment. I think its a green/white wire but I want to check to make sure.
Old May 1, 2005 | 02:25 PM
Thumbs up
I checked all four wires with a voltmeter and also decided that green/white was the most likely. I wired it up and hit the road with the new camper Friday evening. Everything seems to be working perfectly.
Old May 1, 2005 | 06:43 PM
dibble9012's Avatar
yes the green white wire is the one
Old May 2, 2005 | 09:56 AM
yoda-g2's Avatar
Where did you get the controller and how much if you don't mind me asking? And could you please give me a little detail on the install. I need to put one in this month before I tow my 40 all the way to Coos Bay, and I'm still a little foggy on the best way to do it.
I was think that all I would have to do is run 1 wire from the controller and make a way to directly connect it to the brake wire on the trailer. I would like to keep my flat 4 plug in if posible, so I'd just have something basic to connect the two wires together.
Thanks for any info!
Old May 2, 2005 | 01:16 PM
Arrow
I paid $99 from RJays Speed Shop, www.rjays.com, for the controller plus an extra $15 for their generic wiring kit. I was very happy with the generic kit - it had all the necessary wires in the right colors, sizes and lengths as well as various crimp connectors and the necessary fuses. I could have done without it, but saved a bunch of time having it all together like that.
First I picked up a 4-to-7 converter from Walmart. It plugs directly into the existing 4-pin plug and gives you both a 7 and a 4 pin output, then it has a pigtail with the other three wires ending in a crimp connectors. I mounted it to the existing bracket on the Reese hitch.
Using the wire from RJays and a fish tape, I snaked the brake wire from the back up the inside of the frame rail to an existing hole in the frame approximately under the drivers seat. From there I followed the brake lines up the firewall. I connected the power wire to the main terminal in the engine compartment fuse box and the ground to the battery ground up front. Then I routed all three of these wires through an existing rubber grommet on the firewall which brings them out just above the drivers side kick panel.
I mounted the controller bracket to the inside fuse panel cover with two screws, routed the wiring under the dash and crimped it all together. I stuffed the slack wire behind the kick panel.
All total it only took about two hours to complete - it turned out to be easier than I thought once I figured out where I wanted to route the wire from the front to the back.
The next project will be to connect the other two pins in the 7-wire: the 12v AUX and the reverse lights.
Old May 5, 2005 | 10:36 AM
yoda-g2's Avatar
Sweet man. Thanks for the info. I'll hopefully be starting this project in the next few weeks.
gillesdetrail
Nov 19, 2019 12:56 PM
voiddweller
19
May 2, 2016 09:10 PM
YotaGreenhorn
Jun 27, 2015 07:00 AM
ACZR
Jun 23, 2015 07:55 PM
Schif
Jun 20, 2015 08:39 PM
