Leaking Oil?
Old Apr 27, 2005 | 09:30 PM
kevin444's Avatar
Leaking Oil?
Its been probably 2 weeks when i noticed some oily stuff accumulated inside the wheel weels on my driver side rear tire area. Well 2 days ago i decided to clean that crap off so i took off the tire and scrubbed the goo off and tried my best to clean it off the inner sidewall of the tires no sucess. So I drove it a lil bit after and well called it a day. Next day rolled by and out of curiosity i went to check out that clean wheel well but guess what it was'nt clean anymore theres this oily leak that accumulating around the wheel wells again! Im starting to get worried the substance looks clear and to the touch it was pretty thick and oily kinda felt like maple syrup. I poked my head around and i dont see any leaks anywhere else and I suspect it from the driver side rear drum brake.
Jim "jimabena74" gave me some awesome pointers thanks Jim, and he said it could be an axle seal and is leaking diff oil. Or it m might be brake fluid from a cylinder inside the drum assembly.
Have any of you 3rd gen owners experienced this problem? I am running a extended rear diff breather and that doesnt seem clogged.
Old Apr 27, 2005 | 09:42 PM
Tacoma Dude's Avatar
If it were diff oil there'd be a VERY distinctive sickly sweet smell.
That's about all I can give you.
Old Apr 27, 2005 | 09:54 PM
JoKEpLaYeR's Avatar
Sounds like it's the axle seal. Brake fluid is still full and the description of the fluid sounds like gear lube.
Old Apr 27, 2005 | 09:56 PM
kevin444's Avatar
In a way it does smell like diff oil is has a aroma to it kinda like rotten milk or something.
Old Apr 27, 2005 | 10:03 PM
kevin444's Avatar
The puddle is gold in color
Old Apr 27, 2005 | 10:06 PM
User 051420's Avatar
Axle seal. I've replaced mine twice now. Guess what? Chances are you need new brake shoes, too.
Old Apr 27, 2005 | 10:10 PM
kevin444's Avatar
After comparing the puddle to brake fluid. The puddle seems thicker to the touch.
Old Apr 27, 2005 | 10:13 PM
jimbo74's Avatar
axle seal yo....
Old Apr 27, 2005 | 10:51 PM
JoKEpLaYeR's Avatar
Originally Posted by jimabena74
axle seal yo....
Agreed. And with 2 weeks on those break shoes, you probably need new ones like GapGuy said.
jasonty
41
Dec 23, 2018 01:00 PM
Ladythump
22
Nov 9, 2015 08:53 AM
yourrealdad
Jul 21, 2015 11:13 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
