NWOR 3.0 V6 header stress crack repair
NWOR 3.0 V6 header needs stress crack repair
I have had NWOR headers on my 3.0 V6 for just under ten years now with no problems..until now. These are the flangeless headers that seal to the Y-pipe with a ball shaped piece welded to the end of the header tubes.
The weld that holds the ball shaped piece on the end of the passenger side header has failed and now my truck sounds like chitty-chitty bang-bang.
Has anyone had success in getting NWOR to repair their headers under the "limited lifetime warranty"? I'm assuming this piece coming loose should be covered by the warranty, right?
I have taken it to a local muffler shop and they said that most likely, the header is going to have to come off to repair it .
Before I call NWOR, I want to see if anyone else has had a similar problem. And what your experience was in getting it fixed.
Thanks,
Bill
Thanks,
Bill
Last edited by PAhydrohead; 05-04-2005 at 01:59 PM. Reason: Make title more specific
i think you said it best when you said "NWOR...Limited," I seriously doubt they would honor the warranty after ten years. They aren't exactly "service friendly" if you know what i mean.
any updates on this??? I really would like to know if these guys have cleaned their act up recently cause I'm in the market for headers, crossover, & cat back -
Thanks!
Thanks!
Thanks!
Thanks!
I have a guy in my shop right now welding stainless pipe so my plan is to remove the header myself and have it re-welded right here. That way I have the minimal amount of down time.
You could call NWOR and ask them what the warranty covers but I'm pretty sure its parts only.
NWOR sucks when it comes to that. Got a friend that used there socalled headers for a sbf swap and they cracked right after the swap and they would not refund his money
Thanks for the updates- I would have done the same. Why ship something that could just be welded up quick?!
After searching for header info till I had a beard to my arse last night, I finally called Thorley & talked to Randy there. Nice guy! We talked for a good 5-10 mins. - mostly him talking excitedly about this new header he had planned to release towards the end of June. He said something about how they "picked up" Downey's line awhile back (what ever that meant) & have been planning to introduce a new header for us 3.0 guys that will be loosely based on Downey's design but made the Thorley way! He wants to add a ball & socket @ the collector & change their "y" pipe design. I told him that's exactly what needs to be done because w/ Downey & NWOR being the main competitors out there, someone has to step up w/ a good product & good customer service - plain & simple.
So needless to say, I'm going to wait around till Thorley gets this done. Just glad I don't need this asap!!
Also- pass the word on about this new header. Call Randy @ Thorley & express your ideas or enthusiasm for the new parts. Maybe it will help speed things up some & help w/ the design too???
Go Thorley!!
Update:
After rock crawling at Paragon Adventure Park this past weekend the weld is totally wasted and the bolts holding the whole thing together are at their limits. The header is now off the truck and a local stainless steel custom exhaust shop is going to do the repair.
NWOR offered very little help. They said to fax my original sales receipt to them, then they would fax it to the warehouse but the warranty doesn't cover corrosion problems. I would have to send the header so they could see if there was a valid claim. Its cheaper to just get it fixed locally. They did offer to sell me another header!
Originally Posted by bryanr
Guess I know what brand I won't be going with
Peace
Wow, 10 years out of any brand header is pretty awesome! There's no way anybody will warranty something that old. I can't see where you could really complain at all. Nobody makes a header that will really last any longer than that did. Unfortunately, the cost to remove and fix the header is just a side affect of the 3.0 engine.
Originally Posted by Cebby
I thought his were stainless. Maybe they are just chrome plated mild steel.
Most headers are not very thick metal and get fatigued over time from the constant heating and cooling cycles. No header will last for a lifetime. I wonder what they are trying to claim with that warranty but obviously it's not a true warranty. You did pretty good getting 10 years out of them before any damage.
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
