axle seal help
Old Apr 30, 2005 | 11:15 PM
GreenTRD's Avatar
axle seal help
I have a problem with my driver's side axle seal. I replaced it about 4 months ago and it's leaking again, what causes a seal to leak? It is just the driver's side, also the bottom of the diff looks like it is leaking oil, there is no oil on my driveway but the bottom of the diff (about a quarter) looks wet with oil and both the drain and fill plugs are tight.
2000 TRD Prerunner 3.4 w/ lockinf rear diff.
Old Apr 30, 2005 | 11:17 PM
rimpainter.com's Avatar
Be sure to check your diff breather and make sure it isn't clogged. It's on the top of the diff.
Old May 1, 2005 | 12:06 AM
jimbo74's Avatar
diff breather forces oil out when the axle cannot vent properly......
that said, the side you replaced, were you very careful to do it properly? a lot of people figure hey i can do that, then they do it, and the same thing goes wrong later.... not because they are idiots, jsut sometiems big jobs require to actually pay someone to do it, or enlist the help from someone who has done it before with sucess....
Old May 1, 2005 | 12:47 AM
miket223's Avatar
heh, you must have ABS if it's already leaking again. It's a roll of the dice with those. I believe it has something to deal with the seal depth that makes those axle seals quite unreliable and the repairs even more unreliable. Just take it to the Toyota dealer and make them fix it over and over until you get a lucky draw and it doesn't leak. 1 year/unlimited mile warranty including labor on the seal if you buy it from Toyota. Just keep it away from me.
Old May 1, 2005 | 05:40 AM
Bigblock's Avatar
Is there any play in your wheel bearings?
Old May 1, 2005 | 05:42 AM
Bigblock's Avatar
You must also be careful when reinserting the axle so you dont nick the seal.
Old Nov 29, 2005 | 06:18 PM
Ric's Avatar
Ric
Banned - User requested
yea, im digging up an old thread, but for you guys that have done the rear axle seal on a 3rd gen. do you happen to know that part number i need ? and what they cost ? thankx so much
polo451
13
Nov 20, 2016 07:49 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
jerusry
Oct 19, 2015 05:28 PM
yoder519
Aug 17, 2015 07:12 AM
yourrealdad
Jul 21, 2015 11:13 AM
