Question Regarding Jack/Stand Height
Old Apr 26, 2005 | 12:20 PM
4Peanut's Avatar
My 4Runner has an OME lift and 285/75R16's. I'm shopping for a floor jack and jack stands. Does anybody know how much height I need in a jack and jack stands to get the wheels of the ground? Also, the sticker on the driver's door jamb that lists GVW is gone. How much does a 4WD V6 4Runner tip the scales at?
Thanks.
4Peanut
Old Apr 27, 2005 | 04:39 AM
jimbo74's Avatar
the highest i have seen a regular floor jack go is like 19.5" tall..... i have seen otehrs that go higher, but they are huge and way expensive
Old Apr 27, 2005 | 05:21 AM
My99's Avatar
Your truck will weigh in at right around 4,000 lbs with some fuel and other fluids. This is without you or any other heavy objects in the vehicle.
I use a combination of 4X4s and 2X8's nailed together to assist my jack stands when lifting the truck up to do things that require me to have full drop of the suspensin.
Old Apr 27, 2005 | 05:26 AM
jacksonpt's Avatar
Senior Member
not sure about the jack, but I use 6ton jack stands with my truck and they are just tall enough to get my truck off the ground with the tires still on. I bought craftsman stands for about $35. I want to say they are somethign like 24" tall.
Old Apr 27, 2005 | 05:29 AM
FilthyRich's Avatar
I have 6 ton Blue Point (Snap oN) stands. They are plenty tall to lift my truck w/ rougly 3.5" of lift. I also have a Snap-on 5tn floor jack that lift around 24". the nice thing about my stupid expensive floor jack is the it is a true 5 ton jack at any lifted height. A lot of cheaper floor jacks get their max rating when the jack isat full lift.
You get what you pay for when it comes to jacks and stands
Old Apr 28, 2005 | 10:35 AM
4Peanut's Avatar
So I need about 24" of lift out of a floor jack to get the wheels of the ground? I don't like the idea of using 4x4's to lift the truck.
4Peanut
Old Apr 28, 2005 | 10:57 AM
Robinhood150's Avatar
The tallest "normal" floor jack I've seen is around 21". Sears has it for $70, however, I just picked up a huge jack from costco that lifts the same and has way more capacity for $75. The thing weighs 104 lbs!
Old Apr 28, 2005 | 11:28 AM
Jason B's Avatar
Harbor freight jack.
Old Apr 29, 2005 | 08:05 AM
Flamedx4's Avatar
4Peanut
Got a tape measure? Take your jack and your tape measure and jack up your rig and check for yourself.
Mine with 35's (The lift doesn't matter, the axle is higher off the ground because of the tires, not the springs) won't quite lift high enough in the rear with my standard "economy" floor jack, which if I remember right lifts about 18". 20" would do it fine. So yours with 33s would be fine with a basic jack. ON The Other Hand, get a good one, bigger than you really need. You'll never have to buy another that way.
Old Dec 17, 2009 | 07:01 AM
Fo-runna's Avatar
Searching brings up some old stuff... If I'm looking to get all 4 tires off the ground by placing jack stands on the frame, will 24" jack stands accomplish that or not? I've got OME lift and 33's. (I'd go measure but I'm at work, runner is at home... want to order today.)
Thanks
Old Dec 17, 2009 | 11:33 AM
Elton's Avatar
my 3 ton stands did
4x4-runner
Dec 27, 2016 01:58 PM
4x4-runner
Aug 30, 2015 08:55 AM
Shagool22
Aug 14, 2015 12:24 AM
4x4-runner
Aug 2, 2015 09:24 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
