2001 Leather Seat Upgrade.....PLEASE HELP
Old Apr 26, 2005 | 05:32 PM
lr9788's Avatar
Recently I bought leather power seats for my 2001 4Runner. My old seats were cloth manual seats. I spliced the three wires from both plugs together but they do not power the seats. The seat belt sensor works however. Any suggestions on how to get the seats moving??
Old Apr 26, 2005 | 07:07 PM
Phisherman's Avatar
I guess you have the right wires going to the right places since your ground and seat light work. I believe the power seat wire is blue, but that was from a '99 Limited.
My pimp-adjustment (back of the seat) motor was frozen on one side so I removed the cover, pushed the button, and lightly hit the motor with a screw driver until it started working.
Also, make sure you have the blue (or whatever it is) wire fused so it is getting it's own power. I think I used the dome light fuse (15). I haven't had a single problem out of my swap. Hope yours works out as well.
Old Apr 28, 2005 | 12:03 PM
pat161's Avatar
I did the same thing on my 2000, though I had a friend hook them up for me, the person who did it is a Toyota tech so they had access to the wiring before they hooked them up. He did not say why, and I didn't ask, but he had to take the power from the window line instead of the power that was there. Mine is a base model and therefore was not pre wired for the power seats which may have been the reason. Perhaps the wires you are using are not supplying adequate power?
Old Apr 28, 2005 | 12:15 PM
Phisherman's Avatar
Mine is (was) base model as well, window vs. dome light is just a matter of what fuse you want to pick that day.
I think his seats are working now.
Old Apr 28, 2005 | 01:16 PM
kevin444's Avatar
Just get a multimeter and tap into some +12v power souce.
Old Apr 28, 2005 | 02:37 PM
lr9788's Avatar
Well i ended up needing to run a new power wire and thanks to Phisherman my seats are working great, thanks to all for the help
Old Apr 29, 2005 | 12:28 AM
Phisherman's Avatar
Glad I could help. Welcome to the board!
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
