Old Apr 14, 2016, 01:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
QUICK!! How to remove spare tire??
Old May 1, 2005 | 02:40 PM
CZ Eddie's Avatar
LAUGH ALL YOU WANT BUT I NEED TO FIND OUT HOW TO REMOVE THE SPARE TIRE ASAP.
Ran out of ciggarettes and went to my truck to hi-tail it to 7-11 and whahh... my rear tire is FLAT! Got a spare in the back underside of the truck ('99 4-runner) but it's my first truck that had a spare mounted underneath the truck and it's got some weird plate thing holding on the tire. Not a bolt.
Do I just hammer that plate off or is there a release lever somewhere inside the truck?
HELP... NICOTINE FIT HERE!
Old May 1, 2005 | 02:42 PM
terryjmatthew's Avatar
Under the rear seat there should be the necessary tools.
Insert funky tube through hole in rear bumper and turn counter-clockwise to lower tire.
You should be able to figure it out from there.
Old May 1, 2005 | 02:43 PM
DealMaker's Avatar
Eddie, read your manual. In the spare tire tool kit (behind the seat in a truck, in a rear compartment in a Runner) there are tools to assemble a rod. The rod fits into an opening and the spare tire is lowered via a crank system.
Old May 1, 2005 | 02:45 PM
CZ Eddie's Avatar
THERE IS NO MANUAL.
Okay, a kit under the seat.. I'll look for it. On the right side of the hatch was a panel that looked like a jack kit should be in there but I found nuttin. I have the tools needed but didn't find a manual or jack kit. THANKS! I'll BRB
Old May 1, 2005 | 02:50 PM
CZ Eddie's Avatar
Holy CRAP! I would have NEVER gotten that tire off without the super long unwinder thing located under the seat. Had to stick it in a TINY little OBSCURE hole.
Thanks guys! I would have eventually found the spare tire kit myself I'm sure, but Nicotine withdrawal was doing strange things to my mind.
Old May 1, 2005 | 02:52 PM
switchback's Avatar
You won't see the hole in the bumper until you lift the rear gate open either. It is a bit different from the 2nd generations. Once you open the gate, insert the opposite end of the lug nut wrench (which is stored under the rear seat on the passenger side) and turn it until the tire reaches the ground. Waaa Laa!
Old May 1, 2005 | 02:53 PM
Flamedx4's Avatar
My GF had a neat answer - I turned to her and said "How do you remove a spare tire?"
She said "Exercise!"
SFWPOH!
Old May 1, 2005 | 02:58 PM
4unner4life's Avatar
its in ur manual but
1)take the crank shaft out of rear seat
2)theres a little how beside there rear trunk latch put it in the hole and turn and it should come off!
Old May 1, 2005 | 02:59 PM
whoops a bit late
Old May 1, 2005 | 03:44 PM
wiseguymmiv's Avatar
"Do I just hammer that plate off..." WOW.
Old May 1, 2005 | 04:07 PM
fadetoblack72's Avatar
First you have to undo the spark plug wires. Ok then go under the dash and find zip tie number 46 (it will be clearly marked) and remove it. After that all you have to do is put a pipe wrench on the tail pipe and turn. the spare tire will drop right down.
Old May 1, 2005 | 04:13 PM
axon's Avatar
I thought it was zip tie then spark plugs
Old May 1, 2005 | 04:15 PM
Yobroe's Avatar
I'm happy to know I'm not the only retard on this site
Old May 1, 2005 | 04:20 PM
89macrunner's Avatar
very true for me as well
except i dont even carry a spare because my mount is fudged.
oh well thats what fathers are for...hahaha
Old May 1, 2005 | 04:22 PM
rocket's Avatar
omg...lmao this thread is too funny although that pipe wrench step sounds like good idea, maybe i'll try that next time.
Old May 1, 2005 | 04:34 PM
leebee's Avatar
shes a keeper!
SFWPOH!
hey phil!!
that is one of the better responses ive ever heard! kudos to your g/f!!
lee
Old May 1, 2005 | 05:28 PM
Blair's Avatar
Well, what if he forgets to discharge the flux capacitator?
No worries CZ Eddie...you're not the first to ask that question here. And this reply comes from a guy who hooked his battery up in reverse polarity.
Old May 1, 2005 | 05:32 PM
leebee's Avatar
and you guys all laughed at BBB when he wanted to do that write up! the man is a visonary! his greatness is under-appreciated!
(ok BBB, hows that?!) quietly whispered so no one else can hear!
lee
Old May 1, 2005 | 05:39 PM
Blair's Avatar
Hey Lee,
That building in the background of your avatar looks familiar...is that Ajax?
Old May 1, 2005 | 05:40 PM
BruceTS's Avatar
Boy this thread brings back many memories......... RIGHT BBB
