Steering squeel?
Old May 1, 2005 | 05:42 PM
colo-chinaman's Avatar
Steering squeel?
Please don't laugh at me and my dumb questions, but when I turn all the way or when I am on the trail and am wanting to go on direction while the wheel wants to go another (kinda bound up I guess you could say) something starts to squeel. figured it was the belt, I tightened it and it stil does it, I think the belt is in decent shape, kinda stiff but no cracks or anything like that, what else could it be, air in the pump or something? thanks
Old May 1, 2005 | 07:09 PM
93ToyKid's Avatar
It's probably just your steering stops. Is it a loud metal-to-metal squeak at full lock? At the front and back of your lower A-arms, there are this little plastic caps covering your steering stops. These caps wear through, allowing the metal to rub at full lock. You just need to put some grease on these to make it go away. If that's not it, a squeal would also indicate low power steering fluid.
Old May 1, 2005 | 08:22 PM
not the steering stops, its not an ifs unit, its an 85, with an ifs steering box to run the cross-over set up. any other thoughts
Old May 1, 2005 | 08:56 PM
Ironmike4x4's Avatar
It's your steering linkages telling you to stop killing me. The hydraulic units are being forced to work harder *forgive me I;ve forgotten most of what I was taught in steering class* and some sort of component is either stalled or almost locking up *I need to study on that again*. If it were low on fluid, then it would cause a buzzing noise when the air is being compressed.
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
gentry
Sep 28, 2015 06:16 AM
