Is a wider Rear axle worth it?
Old May 7, 2005 | 04:42 PM
RED 85's Avatar
Question Is a wider Rear axle worth it?
Okay I have a 85 Extra cab with 4.88 and a Arb rear locker. I have a 89 4runner parted out with the rear axle stock. Is it worth swapping the rear axles? Will the thirds swap easily? will i have to go with spacers in the front? Will the wider rear actually be better or make that much of a difference? I need to know so i can save it or send it to the juck yard.
Thanks
Brandi
Old May 7, 2005 | 04:54 PM
superjoe83's Avatar
Thanks
Brandi
i put a ifs rear in my '84, it will help reduce tire rubbing on the frame, it has bigger brakes, and bigger axle tubes which i thing is stronger, the 3rd's will interchange, you don't have to go with spacers in the front, i haven't yet without any problems, go for it
Old May 8, 2005 | 07:07 AM
RED 85's Avatar
Hey thanks for the feed back!
Old May 8, 2005 | 09:45 AM
kyle_22r's Avatar
however, you're gonna need to get spring plates from the later axle or do a u-bolt flip -- the tubes are bigger so your spring plates probably wont work. also, you'll have to extend the e-brake cable in the rear.
Old May 8, 2005 | 03:17 PM
toyota parts dude's Avatar
since it's a 1985 the 89 4runner axle is going into you just have to use the 89 4runner spring plates. 85 and 89's both have the shocks mounted to the side of the frame rail.
i just egged the holes out a little on my 81 and 82 truck to get the bigger ubolts to work. it's been that way for 5 years on each without a problem.
Old May 9, 2005 | 07:10 PM
RED 85's Avatar
I have the whole truck so i can take from it what i need and will someday be doing rear disc bracks so the e brake cam be jimmied.
I was thinking of just welding the springs to the axle and then duct tape over it to make sure it would stay.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
toyoda8488
Jul 5, 2015 10:18 PM
