- Backfiring 3.4 5VZE no CEL Help!
- Won't pass inspection...
- Steering Wheel Locked
- P0420B error code
- HELP!!! The Rear Door Weather stripping ripped out!
- 95 tacoma 2.7 oil pump
- 98 Tacoma questions!
- Transfer case grinding - 2000 4Runner
- Can I get away with using non-OEM clutch master and slave cylinders?
- Aftermarket Sprinss for 2000 4Runner
- random/multiple misfiring codes
- Intake manifold/Fuel Injector clean
- New member introduction
- Flashing SRS - anyone experienced this?
- 98 T4R LTD replacement internals for front carrier? Houston, we have a rumble.
- Towing with auto 2wd 3.4 96 4runner
- Tundra 5100 lift question - perch notch
- Front Coil Over Shock Removal 97 4runner
- How can I press on transfer case flange studs?
- Odd lack of acceleration '01 4x4
- 99 4runner auto trans problems
- 98 Tacoma Engine Swap, Suggestions?
- Ok to replace spark plugs at diferant times?
- Led headlight conversion
- Before boost maintenance items
- 3.4 L no compression. bent valves?
- Tire matching question
- DIY Windshield Washer Fluid?
- Cigarette/Power Outlets Dead, Fuses OK
- 2004 Tacoma Breaking Issue
- 3rd gen Runner front lift
- 3 speed automatic shifts 4x
- How I ruined my 4runner
- Lockers for my 2wd
- Found a set of wheels i want to buy for my 4runner. Got a question though
- What grade are the oil pan bolts?
- squeaks and leaks
- P0172 code on 3.4. Long and Short term fuel issue on bank 1
- Replacing battery cable - 1996 Taco
- Grinding sound at highway speed after lift?
- Brake Light VSC OFF VSC Trac ABS light on (no CEL)
- grabby steering on small bumps
- 4runner 2002 engine upgrade
- No heat
- Taco front lifts
- PO300 & PO302, CEL, misfire
- Unsteady Idle
- 2000 4Runner Lift Kit Help.
- What is the harness for?
- complete newbie questions
- FJ cruiser springs and shocks on 4runner ??
- First Gen Supercharger Removal/uninstall questions
- Which are the correct front wheel bearings!??
- Grinding from clutch/trans area
- Passenger side rattle driving me nuts
- Pan bolt torque on a a340f trans ATP brand gasket
- Lbj failure....replace uppers?
- need help with abs brake issues
- 3rd Generation front end rebuild kits
- Replacement headlight options
- 231 mm Tundra Upgrade Quick Question
- Horn doesn't work.
- My First Toyota
- 99 Tacoma not shifting as well after redline mt-90
- Bolts on torque converter
- Seats Question
- Dome Light/Warning Chime
- Busted electrical plug on top of 96 4Runner transfer case
- 1996 4Runner - Intermitent Starting Issues
- p0141 code... wrong rear sensor?
- 1996 4runner sr5 3.4 low idle and stall problem
- 1996 4runner 3.4 low idle and stall problem
- 2000 4runner a340f kickdown cable (tv cable) broken
- 1997 4Runner What do I need to look for?
- Thread for programming options digital cluster
- Converting to the Newer Generation...
- Another 4wd not working thread
- Climate control switches in cab not changing
- RS3000 installation instructions needed.
- Problem with cold start
- Air conditioner compressor won't turn on
- Brake Booster Failure
- 2002 4runner transfer case fluid
- difficult door lock
- starter repair
- misfire code issues
- '98 4runner strange noise *video*
- 2001 4runner Ignition Lock Cylinder Replaced
- 1995 taco 3.4l Evap can
- Cracked Cylinder Head or Blown Gasket help
- Overheating issues
- Air filter soaked in gas
- front axle change out
- 2001 Tacoma will not engage 4wd Low, will engage push button 4wd high...help!
- How Do You Install a Metra Power Antenna?
- headlight & turn light wiring adapters
- My buddies a knob
- Aftermarket steering wheel
- P0420 check engine code
- 2001 4Runner 4WD NOT engaging - need more suggestions
- Tacoma 3.4 knock sensor codes! Need advice!
- 97 taco front. 02 sensor replacement: how to tips
- Circuit Open Relay on '98 4runner
- Rear Diff Leak
- need help installing boost gauge 3.4L 99 tacoma supercharged
- 96 limited auto to manual swap
- Squeaking when coasting
- 2000 4runner mods
- Blinkers blink fast but all bulbs good?
- Disconecting o2 sensor bank 1 conector
- 1996 4Runner (3.4) Clutch Replacement
- 99 4runner limited hit in the rear parts question
- Help! It's Christmas Day and I broke my girlfriends 4Runner - after stereo install
- Any anti slosh solution for 3rd gens 4runners????
- Clutch problem right after an accidental stall 2003 Taco 4x4
- rear axle seal problem solved
- Help with o2 sensors
- Breather mod ? So - how do you get the gas cap seal off ?
- Anyone ever put Air Bags on a 3rd gen 4Runner
- plow on 95 taco
- V6 Acceleration / Power Issue
- P0135 and P0141 after replacing both O2 sensors, 2000 4Runner
- Gouge in new water pump. Should I worry?
- Help I need a wiring diagram for the 4wd circuit on a 1997 4runner
- Starter, solenoid problem SOLVED- 98 4runner
- Cheapskate lift or bad idea?
- 95 tacoma 3rz fe gas mileage
- P1300 Code on a 99 T4R
- 1997 t100 engine into 1996 toyota tacoma
- Car brakes are sticky but fine in reverse. Stumped 3 Mechanics. Need help!
- Temp gauge not working, bottom coolant hose cold after HG replacement
- Stalling Truck
- Headlights turn off randomly when driving!
- 97 4cyl into a 95??
- trailer rims fitting at taco?
- axle u bolt help
- Transmission / T-case Compatibility 4wd Conversion
- 4Runner dying, should I fix?
- Bump When letting Clutch outq
- Location of stock keyless entry module?
- 2000 4Runner Clutch issue????
- Clutch whine but not the normal one
- Which one to buy? V6 or 4 cyl
- 2001 4Runner SR5 TRANSFER CASE STUCK!! HELP!!!!
- 1998 4Runner Limited Cost to Replace Airbags
- timbren for tacoma?
- 1995 tacoma rear spring and lift
- '96 Tacoma 4wd Not Engaging
- Light bar on roof of 3rd gen?
- Timing the 5VZ-FE
- Help me with my timing belt
- Energy suspension or OEM bushings on my 99 runner?
- My truck makes some good coffee..
- 98 4Runner Steering Issue
- 3.4 Intake seal and knock sensor harness questions
- How to avoid a wet distributor on a 3RZ-FE
- Power Steering Pump or Steering Rack? *VIDEO*
- Part #? - Exhaust Gasket (2002 ext cab - 4x4 Manual 3.4l)
- Light Truck (Load Range C/D/E) tires vs P-Metric tires?
- 2002 4 Runner misfires on 1-3-5
- 3rd gen 4runner tail lights, Weird problem
- '98 Limited... Coilovers vs Sonoran?
- Got Hit Headon by a Semi Truck this Morning
- New Tacoma 4cyl coils on 3rd gen 4runner limited?
- 95 taco frame repair
- Coil Over Lift Kit for 3rd gen Runner
- 95 tacoma reg cab leaning to left
- blown head gasket check list....
- 1996 Tacoma heat luke warm at best... think I found the problem!
- fuel pump removal ideas???????
- which water pump?
- What is this box in my engine bay?
- Weird Brake Issue
- Random hot rear brake
- Brake Pedal Goes Hard
- Clicking/knocking noise while accelerating 96 4cyl 5-spd
- Power Window & Door lock problems???
- 97 4runner tires
- High idle!? 97 4runner sr5
- Sway after Tundra brake upgrade
- 97 4runner radio works when it wants to??
- Another 4runner won't come out of 4wd thread
- Beefed up skid and steering limiters
- 5w-20??
- Rear Wheel Screeching
- 95 tacoma 2.7 idle prob
- valve cover gasket question
- Starting/Ignition Problem
- what year is my 3.4?
- Toytec ultimate lift kit
- Black Windshield Molding - Reusable?
- 1996 3rz-fe valve shims
- Tundra brake upgrade problem
- Alignment out of wack!
- '96 Anti-Lock Sticking
- LBJ 4 bolt torque spec confusion
- lower intake torque on 3rzfe
- Where to buy fender flare stick on rock guard? Or better solution?
- Runs rough after changing gears
- 96-98 Headlights vs 99+ Headlights
- 93 4x R.I.P. Hello 04 Taco!!!
- When is the V6 a good idea
- Some questions for newb.
- 2.7 3rz timing chain
- CA smog high HC @ 15MPH 51ppm and starting issue
- No sway bar = Irregular tire wear?
- Body Damage Questions
- How much rust is too much?
- 01 3.4 tacoma smoking
- How much? Worth it?
- Heating issues
- Operation: PATWGN Rear Bumper!
- 1st time 4runner owner bad tranny
- timing kit on 95 tacoma 2.7
- New Boots...
- trans is toast
- 01 4runner VS 01 Tacoma front suspension
- URD 7th Injector Wiring Help
- Can't get hot.
- 2000 runner 4wd fix
- lbj failure...my turn.
- 3rzfe balance shaft
- Speedy's Liift Install "How To" with Video
- Tack Welding axle bearing retainer? HELP ASAP
- 97 4runner front wheel bearing
- 95 tacoma 2.7 oil strainer gasket
- 1998 toyota tacoma
- A/T Transmission ID Help Tocoma & 4runner
- Tacoma master cylinder swap
- Grey (red/blue) wire mod ABS light
- Is this normal?
- must i remove axel all way on 95 Tacoma to get out the front diff
- 3rz oil pressure problems
- 95.5-04 tacoma
- Lower intake torque specs 5VZ FE
- help where to find bolt torque
- Valve cover gasket question
- Help - front suspension problem
- exaust help on 3.4
- Coilover Snapped?!?!!?
- 95 tacoma 4x4 front diff removal
- 96 3.4 Tacoma engine knocking - help
- 03 Taco sludged engine ?
- Anyone work at a dealership who can look this up?
- Just did the 180k mile service
- School me on 3rd gen 2wd stuff.
- Help. I messed up my 3.4 heads.
- Please HELP, problem with 1996 toyota tacoma
- Thump after complete stop...
- yota rot: rear control arm mount rusted away..
