Bump When letting Clutch outq
Old Dec 12, 2013 | 06:43 AM
tpg013's Avatar
Junior Member
2004 Tacoma, V6, 5 spd, Extra Cab.
Of late every time I let the clutch out from a stop I feel a thud or bump. I do not think it is axel bind as I have greased the slip. Could this be carrier bearing starting to go? I also have an intermittent sequel, sounds almost like wind thru a small crack, when I let off the gas. this can happen at any speed in any weather. The sound seems to be coming from about the spot the cab and bed meet or about the same location of the carrier bearing.
Could the bearing be on it's way out? If not, any ideas?
Old Dec 12, 2013 | 07:02 AM
tantacoma's Avatar
Check the u-joints for play.
Old Dec 12, 2013 | 07:12 AM
tpg013's Avatar
Junior Member
U joints seem to be tight. Cannot move driveshaft at all.
Old Dec 12, 2013 | 09:05 PM
tantacoma's Avatar
You should try to figure out exactly where the noise is coming from.
Have a buddy let out the clutch while you are along side of the truck. It would really help to narrow down which end of the driveline the noise is coming from.
Old Dec 13, 2013 | 04:55 AM
tpg013's Avatar
Junior Member
the sequel is too intermittent to have someone along side. Sometimes it happens at high speeds, sometimes low speeds and sometimes it doesn't make any noise at all.
The bump can only be felt not heard. Feels like under my seat .
Old Dec 13, 2013 | 06:56 AM
KZN185W's Avatar
try greasing your propeller shafts. that has shown to be the solution to similar probs in many cases.
Old Dec 13, 2013 | 07:15 AM
tpg013's Avatar
Junior Member
Did that already. it's where I began when the symptoms first appeared.
Old Dec 18, 2013 | 01:09 PM
Cameoman53's Avatar
, my truck is a 2000 tacoma SAS so some things might be diffrent, but heres some ideas, i have had this happen to be twice, both times fixed, first time the slip yoke seized on my front draft shaft so every time i would hit a bump my transfer case would slap against my body and i would feel it right under my butt/seat, the second time was actually last week after wheeling on my way back down i had the same sound/feeling under my butt but this time it wasn't my slip yoke on my drive shaft, i had a bolt back its self out on my transmission cross member and another almost all the way but was jammed before falling out, so every time i would give it some gas in reverse or forward and torque it out my transmission would have some play, and the transfer case yet again would slap itself on the underside of my body and i would feel it on my feet/butt, i hope that helps
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
May 20, 2016 10:27 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
PlayAwhile
Jul 20, 2015 11:36 AM
